Old 01-25-2009, 03:13 PM   #1
Default Methods for cleaning/lubricating bearings?
what way do you use to clean and lube your bearings? Ive been using the motor spray with rpm bearing blaster and 3 in 1 oil but I would like to hear your suggestions! For some reason after I do the bearing blaster the bearings feel a little gritty so the last time i just put the bearings in 3 in 1 oil. This is for wheel bearings but methods should be universal for almost all bearings right? thanks!
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 01-25-2009, 03:23 PM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
there are lubes special for bearings. i carry heavy light and regular bearing lubes but normally use wd 40 to clean and mantain them
Mark Buecker
8&stuff is offline   Reply With Quote
Old 01-25-2009, 03:25 PM   #3
I also have trinity light bearing oil but I dont think it would hold up in wheel bearings. So you just spray wd40 and leave it? That can be pretty convienent if it works, since I clean my buggy with half wd40 I can just spray it alot in the wheel bearings....
Old 01-25-2009, 04:54 PM   #4
Integra's Avatar
1$ a peice....Just toss em and use new one's....its not worth it to have a bearing lock up and take you out of a race imo.
Old 01-25-2009, 07:58 PM   #5
Where are they $1 a piece? Since I clean my bggy after every weekend....it could get expensive especially for someone who is on a tight budget. Right now im just hitting up all the tracks socal has to offer just practicing.
Old 01-25-2009, 08:20 PM   #6
David Wall's Avatar
Where are they $1 a piece? .
Avid Revolutions! $1.00 each
Retired!
David Wall is offline   Reply With Quote
Old 01-25-2009, 08:25 PM   #7
fast11970's Avatar
+1 bad bearing, clunk! ZTrash... Easy , fast and...effective!
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 01-25-2009, 08:37 PM   #8
Integra's Avatar
where aren't bearings 1$ a piece ?
Old 01-25-2009, 08:56 PM   #9
Integra's Avatar
huh ?
Old 01-26-2009, 07:18 AM   #10
I always thought the Losi bearings were more expensive but never really checked into it.
Old 01-26-2009, 07:21 AM   #11
Integra's Avatar
the losi's sure are...but any bearing mfg will do....Avid Protec Boca...they all have buck a bearing line ups.
Old 01-26-2009, 07:50 AM   #12
wallot's Avatar
Cleaning ; RPM Bearing blaster + any nitro cleaner
Relubing - Acer bearing lube or any other light bearing oil
Works mostly on bearings with at least one metal shield
I use it only to get rid of grease in standard bearings and relube them with oil for less friction (I use half metal half rubber shield bearings everywhere except center diff)
cheap bearings : abec35.com, readyrollers.com, avid and many others
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 01-26-2009, 09:29 AM   #13
cdbias's Avatar
Get some Boca Bearings yellow seal ceramics and just forget maintenance period. I've had them in mud twice and a couple of super "gritty" tracks that are know to chew stuff up. No problems and I've used several bearing companies. They are worth the money!
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 01-26-2009, 09:56 AM   #14
PTP Racing's Avatar
ReadyRollers.com
Good quality $1 bearings are available there. Ive been using them for a year and they are better than the other brands I have tried in the past for the same price.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 01-26-2009, 12:30 PM   #15
Dont listen to this dude. No matter how pretty the wrapper is or what materials they are manufactured from, forgetting bearing matinence is ignorant. I like ANY bearing with two rubber seals. They keep dirt out better and are easier to take apart to clean. I clean them about every 1/2 gallon with brake or carb cleaner and compressed air until they spin fast without chattering or sounding gritty. If they never do clean up i will replace them. I usually find the start of a problem before it gets bad enough to cause a DNF.
I repack them with automotive axle grease then blow the excess out with low psi compressed air. Put the seals back on and put them back in the car. Sometimes I will take the seals off the inside-side of the bearing in the hub carriers. $1.00 bearings are a good idea for a supply of spares.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
