Old 01-25-2009, 10:44 AM   #1
heeltoedrver's Avatar
Exclamation CRT .5 Servo Horn Size
What size servo horn do I need for the steering servo so that it clears the radio plate when I am running the extended chassis. Because I am running full size servos it seems as if I need an extra long horn to get maximum travel without hitting the top of the plate. Thanks fellas!
Team Terribles
heeltoedrver is offline   Reply With Quote
Old 01-25-2009, 01:10 PM   #2
Trader Rating: 171 (100%+)
Ya got me looking their, on one of my crts.5 I run a dynamite aluminum and the other crt my son has the cheapy, one size fits all ones on the dynamite one it has room at the top to be mounted up higher and the cheap one is in the top, and both clear the top plate without touching
Troubles Dad is offline   Reply With Quote
Old 01-25-2009, 01:32 PM   #3
much appreciated! yeah, it was kind of a thinker, i know i was scratching my head for a while. ill likely go with dynamite horns for steering and throttle.
Team Terribles
Old 01-25-2009, 01:38 PM   #4
they are cheap and work great for the truck, what diff oils do you run, as I am still fine tuning mine
Old 01-25-2009, 02:18 PM   #5
i am yet to even fire mine for the first time. however, i have read all 70 pages of the forum, talked to a few local racers, and talked to the ofna tech who frequents the forum and im thinking 3k 3k 1k for diffs. shocks are going to be 60wt 1hole piston blue spring and 40wt 2small hole piston and grey spring. well see how it runs in the spring
Team Terribles
Old 01-25-2009, 04:18 PM   #6
I changed mine from 3,3,1 to 3,3,3, I have read them 70 plus pages and looked for better info, these trucks are simply amazing, at a track, I can keep up with the pro-buggies, doubles, triples, just don't be afraid to break it, as I tumbled down a 150 foot straight away, while talking to my son and only broke an upper tie rod link, drive it like an 8th scale and you will only want to drive it more and more and I run the little picco 3 port [ I think]
Old 01-25-2009, 05:55 PM   #7
much appreciated info! why did you go from 3 3 1 to 3 3 3? how did it react when on 3 3 1? what changes did you find when you went to 3 3 3?
Team Terribles
Jammin CRT .5 = 1/12 Truggy Team Kamikaze Nitro Off-Road 2269 07-02-2017 04:32 PM
