Old 01-24-2009, 09:14 AM   #1
Default My experience with Caster K8T comapred to my 5T......
I am comparing my Caster K8T to my Mugen MBX5T Prospec.
I ran the 5T for 2 years. I just got it dialed in to my driving style, but still could not get the on power steering I needed to move forward and get FASTER. But none the less I loved my 5T and was getting faster and faster each race and had a lot of time on the track with it. I felt like I hit a spot where I just may not be able to get faster.
So heres how these 2 truggys compare for me. I ran the K8T with stock set up out of the box, same with 5T. I don't want to get all crazy talking set up right now.....but in 2 years with my Mugen I was doing 12 laps @5.21 on the last layout at my local track. With my K8T on the same layout( Same layout for a month and I ran the 5T on it the first week and the K8T the last 3) I lowered this to 12laps @5.01, and I crashed a few times and was very nervous. I have never done 13 laps at this track! and I was right there!!! Plus with the K8T I have found a set up that gives more on power steering then I have ever had with the K8T! It has changed my entire drivivng style now that I can power thru turns and give it gas where as before(5T) I could not. So for me the K8T has already showed me its ability to be very tuneble and have tremendous handleing. And all this with worn tires on my Caster truggy and motor issues. I know that with the 5T I was really learning setup and by time I got the K8T I had a good idea what I needed. But in the end I set both the truggys up exactly the same and there was a 20 second difference between the 2 and the Caster truggy has the on power steering I have always wanted. These 2 truggys are almost the same feel when racing, but you ask anyone that has a 5T and they will say the same thing, needs more on power steering...in the K8T I found it!
xutmad is offline   Reply With Quote
Old 01-24-2009, 10:45 AM   #2
scwrod's Avatar
word.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 01-24-2009, 11:30 AM   #3
Oasis's Avatar
Trader Rating: 36 (100%+)
Wait till you drive a truggy that can really turn..Their is no way around the "to much caster" Caster..I have both the Mugen and the Caster in my opinion their both so close to each other. But I am running the King Headz steering plate and it does move the ackerman settings to the rear. It does get rid of a lot of the bump steer that both the Caster and Mugen have. If you put the Caster on a set up board you will see that it has about 30 degrees of caster, a Kyosho ST-RR has about 18 degrees of caster. With 30 degrees of caster their is no way that it will be agressive at far as turning goes..It will however be very stable and very smooth, and the Caster is shorter than the Mugen also, this helps the truggy rotate in the corners. I would like to see the next Caster use less caster( 20 to 24 would be good) and move the motor up just a bit..small changes would make a huge difference on the track. I hope that no one takes this as a slam on the caster, I think it's a very good truggy with a good company behind it..every truggy can be improved.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 01-24-2009, 12:57 PM   #4
Trader Rating: 27 (100%+)
Xutmad - What do you mean "But in the end I set both the truggys up exactly the same."
How exactly did you set them both up the same?
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 01-24-2009, 01:02 PM   #5
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Hey man, Glad your having good luck with your truck. I had to get out of the team due to feeling I did not have the money to correctly represent them this season. So im still running Kyosho's. But its awesome your trucks doing good.
-Mikey
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 01-24-2009, 01:32 PM   #6
I set them up both the same as in, Diff oils, rear toe plate deg, Arms positions, just tried to do the exact same thing to both of them to see which one did what I wanted. These 2 truggys are almost identical, in fact they are so close they can share parts, so you can make both of them pretty must the same when it comes to set up.
Old 01-24-2009, 01:34 PM   #7
Trust me Oasis....I know your a Caster fan, and you have never said anything bad to me. Oh by the way...did you mail that stuff out to me yet??? And to the right address.LOL!!!!!
Old 01-24-2009, 11:07 PM   #8
vnmsgt's Avatar
I agree with OASIS. I cut my front upper arms with a dremel where they but up against the front shock tower so I can move the arms up and get less caster. This has made my K8T turn alot more aggressively like Oasis said.
Glad you are liking the truggy. A couple guys local to me say there K8T turns and handles better than there 5T that they ran previously. Never said anything bad about the Mugen just that the K8T seems to suit them better.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 01-25-2009, 07:11 AM   #9
No I can't say anything bad about my Mugen at all. Just never could get it to do what I can make my K8T do, thats all. The Mugen 5T to me is still at the top of the truugy list in my book.
