Old 01-23-2009, 04:53 PM   #1
Default Rb Air filter set issue... Help.
Does anyone use the Rb air filter set for the c6 l2g? I have it on mine, and I just can't figure out a way to mount it under the body. I mean it just doesn't fit. I have an 8ight with the stock body. If you have it, what body are you using? Or how did you make it fit?
Cvdiver is offline   Reply With Quote
Old 01-23-2009, 05:29 PM   #2
r1harper's Avatar
Trader Rating: 24 (100%+)
i used a shorter elbow...on truggy the stock one is fine
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 01-23-2009, 05:42 PM   #3
Im sure someone will correct me if im wrong, but Losi designed there air filter for the 8IGHT to be different than the "standard" off-road air filter. I guess there just wasnt enough clearance. Some filter sets simply just wont fit under the factory body.
If no one chimes in with a body that will work with your filter, or there isnt one, here is you best bet....http://carolinasrc.com/Webstore/Scri...idproduct=2677.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
