Old 01-23-2009, 09:10 PM   #16
Trader Rating: 27 (100%+)
Originally Posted by 22Racer View Post
I usually just go by the size, although I measure in different spots around the pin. Most crank pins are 5mm, except for Rb's. I consider .002 inch wear to be done but will run if you need it, which would be pretty close to your 10%. Some crank pins wear all the way around more than others.
I have ground cranks and made smaller bushings in the rod but with not enough success to do it for customers.
Rex
Hi Rex, sent you a PM about a pinch. Can you PM me the price of a go 5 port as well? I will be looking for one come spring. Time I check one out for myself. Thanks.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is online now   Reply With Quote
Motor Mods.....sleeve's pinched racer_RR R/C Items: For Sale/Trade 178 07-21-2009 10:58 PM
Pinching a motor.Who do you use?. What are the PRO ancd CONS. Mpowerz Nitro Off-Road 66 04-19-2009 07:05 AM
Engine Change madbeats Nitro On-Road 10 10-20-2008 08:46 AM
Brand new NovaRossi P5X difficult to start, locked up? Cannondale1974 Nitro Off-Road 10 04-02-2008 07:35 AM
My 1/10 Scale Dirt Oval Sprint Car Jsumner01 Oval, Larger Scales and More 14 06-17-2007 02:01 AM
