Old 01-22-2009, 08:14 AM   #1
markr04's Avatar
Default MBX5 Prospec flywheel worn/smooth, wearing starter box wheel
My MBX5 Prospec has a worn flywheel. My starter box has trouble gripping it and I've quickly worn a groove into the starter box wheel. Add a little fuel spillage on a typical day and it won't even turn the engine over once. It's basically become a real pain to start and a pit guy volunteer is going to have an even harder time than I do.
I've considered taking my Dremel to the flywheel and lightly "re-grooving" it so that it doesn't look like a worn out U.S. quarter.
If I need to replace the flywheel, what are my options? I know I can use a Mugen replacement, but I also heard I can use an Ofna one. Are there any aftermarket flywheels?
Any other suggestions?
Thanks!
markr04 is offline   Reply With Quote
Old 01-22-2009, 08:23 AM   #2
I have done the dremal trick to two of my losi flywheels with good success.
clebo3 is offline   Reply With Quote
Old 01-22-2009, 08:26 AM   #3
Suspended
Trader Rating: 440 (99%+)
There are many other flywheels that will fit. The key is making sure to get the same size as your stocker.
You also have the option of running a complete aftermarket clutch setup as well that includes a flywheel and shoes..etc...
Fioroni adjustable setup:
http://www.amainhobbies.com/product_...oducts_id/7941
Fioroni "turbo sliding clutch":
http://www.amainhobbies.com/product_...ducts_id/13236
Stock mbx5 flywheel:
http://www.amainhobbies.com/product_...oducts_id/1851
MattP is offline   Reply With Quote
Old 01-22-2009, 10:01 AM   #4
Trader Rating: 27 (100%+)
Less than five minutes with a dremel or a file and you will be back in business with no money spent.
Are you sure it's lined up perfectly on the starterbox? Just a hair off will cause big problems and hard starting.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
