Old 01-22-2009, 07:17 AM   #1
Little Duckling's Avatar
Arrow TRX 2.5 Nitro Engine
I have a TRX 2.5 engine that I took apart, previously used by someone else, and I took some photos of the piston. I think theirs something wrong with it. The colour of it doesn't look so good. What do you think?
Pics:
Little Duckling is offline   Reply With Quote
Old 01-22-2009, 10:04 AM   #2
Dalepad's Avatar
It's hard to tell in the photos but it looks like it has carbon build up from being used. Does it run?
Dalepad is offline   Reply With Quote
Old 01-22-2009, 10:51 AM   #3
chunk t's Avatar
+1 this engine has a lot of hours on it using a high oil content fuel on a rich needle. What I like about the photos is you can see some interesting things going on. The sleeve has a consistant color, so I know it's never been over heated. @ 7 o'clock the pistion face there is pretty clean area under the squish band. I bet there's a trasfer port there & it has a lower timing than the other trans-ports. On the block next to the sleeve from 12 -1 and 5-6 o'clock you can see the dark burnt oil residue. I think if you did some really careful measuring, you'll find that this sleeve's been pinched at least once.
I'd be curious to see what the inside of the sleeve looks like above the exhaust port. Is it whitish or gold "brassy" in appearance.
Cleaning the engine will remove the built up carbon and sludge, that also means tolerances will be opened up (loss of compression). If the engine ran good before you lifted the head, I'd say only wipe the piston face (w/o removeing from the sleeve) and wipe out the head, then run that little fella' til the cows come home. A good thorough cleaining will mess up the fit between the P/S on a heavily used engine like this one.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 01-22-2009, 10:57 AM   #4
Jaz240's Avatar
Trader Rating: 52 (100%+)
Chunk I am forwarding all my engines questions to you from now on!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-22-2009, 11:19 AM   #5
Would you recommend replacing anything?
Old 01-22-2009, 04:48 PM   #6
chunk t's Avatar
Depends on your objective? If you're just looking for a basher. I wouldn't do a thing to it if it runs OK. If you have to rely on it as your primary engine for racing & practice... new bearings are always a safe bet, if the sleeve hasn't worn through the nickle plating, a pinch wouldn't hurt and a replacement con-rod. but you never really know what needs/should be done until the engine is totally disassembled, cleaned and measured. If you are going to end up spending a lot of repair money in the engine, consider Traxxas engine swap program. that may be the most economical way to get a reliable new engine w/o buying the farm.
B-Mod Tunnels
Old 01-22-2009, 05:00 PM   #7
I just have one last question, would it do any harm if I painted my nitro head with some VHT Flameproof Coating? hehe
Old 01-22-2009, 05:32 PM   #8
Jaz240's Avatar
Yes! Dont paint it with anything. Chunk T will yell at you
Old 01-22-2009, 07:01 PM   #9
dieseldog20's Avatar
Send a message via AIM to dieseldog20 Send a message via Yahoo to dieseldog20
from the views of the first picture, if you look at about the 9-11 oclock positons you will see wome light. I dont know i i am seeing things but it sure looks like some light shinning through. If it is light it seems to be worn pretty good, but over all the piston and sleeve look in pretty good condition.
dieseldog20 is offline   Reply With Quote
Old 01-22-2009, 07:37 PM   #10
chunk t's Avatar
Don't listen to me. Listen to Jaz
Paint will act as an insulator and help hold in the heat. The anodizing that the MFGr uses is actually a dye (pigment) added to the metal. So it's a completely different thing from painting or any type of coating you may want to apply.
Jaz... careful how much faith you put in what you think I know. You have NO IDEA the trouble I've been able to get myself in
B-Mod Tunnels
Old 01-23-2009, 04:12 AM   #11
Thanks, you guys are great help.
Adelaide Nitro Offroad Racing Club oblivion Australian Racing 19736 01-14-2017 01:12 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
NITRO 4TEC Parts TRAFFIC R/C Items: Wanted to Buy 23 09-15-2006 02:49 AM
best nitro engine for the $$ beetlebz Electric Off-Road 9 08-27-2004 04:39 PM
