Old 01-21-2009, 08:49 PM   #1
1lowtaco's Avatar
Default cleaning fiberglass disks
i had my center diff gasket go out on me and it blew diff fluid all over the brakes. what how should i clean them?? i was thinking simple green, then scuffing the pads with sandpaper.
1lowtaco is offline   Reply With Quote
Old 01-21-2009, 09:03 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
wipe em clean, and sand em, they'll be fine
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-21-2009, 09:06 PM   #3
1lowtaco's Avatar
what about the fiberglass rotors?? should i sand those too??
Old 01-21-2009, 09:16 PM   #4
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
LIGHTLY with 1000 grit sand paper
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-21-2009, 09:26 PM   #5
1lowtaco's Avatar
ok, i will give that a try. i was just afraid of breaking open the fiberglass.
Old 01-21-2009, 09:27 PM   #6
pinky2252s's Avatar
If you do just stop, and it should be fine
Team Terribles
Old 01-21-2009, 09:34 PM   #7
Jaz240's Avatar
All you want to do is sand off the oily residue, from the calipers and rotors, very lightly, you will know when its gone, try not to get to much of your finger oil on them either. Hold the edges
Old 01-22-2009, 08:44 PM   #8
Integra's Avatar
Vigorously sanding them will bring them back to new...but you'll have to be careful to not go too far over time without checking the gap's on the cam's and everything...i ran my Old HD disc's till they were too thin and were binding up the brakes and causing all sorts of issues....the new 2.0 discs/pads are much thicker and should last Alot longer.
Old 01-22-2009, 09:12 PM   #9
fast11970's Avatar
I use these..Instead of sand paper. Abrasive enough, not so aggresive ...
http://solutions.3m.com/wps/portal/3...gl7TBD12ZDNTbl
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 01-22-2009, 09:56 PM   #10
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
to remove oily residue why not use denatured alcohol and a cloth,, submerge the discs in there and rub of any excess on the surface
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 01-22-2009, 10:08 PM   #11
pinky2252s's Avatar
that would work
Team Terribles
Old 01-23-2009, 04:50 AM   #12
1lowtaco's Avatar
thanks guys, i am just gonna try cleaning them. i don't think sanding them is a good idea. i just don't want to ruin them. back in the day when i raced bmx i used Simple Green on my rims to get the brake pad residue off. that worked really good
Old 01-23-2009, 07:30 AM   #13
I use the softest buffing bit on my dremel, takes 5 seconds
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 01-23-2009, 08:11 AM   #14
NorNevRC's Avatar
i use denatured alchohol then use 800 grit cloth. sanding in a figure-eight motion to ensure the surface stays flat. this will show and fix any minor imperfections.
i would'nt use a dremel.
B4, BJ4WE, SC10, RC8e, XRay T2R Pro
NorNevRC is offline   Reply With Quote
