Hot Bodies D8 Truggy
#7936
#7937
Truggy diff spacers are there to keep the spur gear from extending below the chassis.
D8 not needed, hara d8 or d8 with 3mm chassis needed.
Diff oils, depends? Nice starting point 7-10-3
When storing-try to keep wheels off the ground, helps extends life of arms, little sag not to bad,alot time to change.
Everyone had their opinions on Diff fluids and Personally I always end up back at the stock 7f, 7c, 3r or 4r.. To me it just works. It might not be the absolute best at every track..
#7938
What would be the difference between running 10 in the center than 7
I personally dont race just my son does
thanks
thanks
#7939
Diff oils depend on the size of the track I think. I would start with the stock 7-7-4 and go from there. I run on a medium sized track with medium to high bite and I really like 5-7-2 for my diff setup. Good acceleration with 7 in center, smooth rear end with 2 and massive amounts of steering with 5 in front.
#7940
#7942
Think of it like this. 100,000 center diff fluid will essentially lock the diff gears send 50% power to front and 50% power to rear. No diff fluid would send the power to the front or rear, which ever has the LEAST amount of traction..
The differences between 10k and 7k in center is pretty subtle, but if your really paying attention you'll notice the difference..
#7946
Hey bud, just got the hellfire ones today to try in my team c truggy ( which has very little down travel). I dunno if I will put them in either of my d8t but 3 mm will go along way!
#7947
Hellfire axle end (bigger) won't fit in d8t stub axle so you will need hellfire stub axles as well. I will sell you my two new axles if you want them as I have no use for them now. The team c truggy has captured Cvd pin in the bearing. Lmk.
#7949
