Old 01-21-2009, 02:20 AM   #1
Default Nitro car problems
Hi guys
Well my tamiya mighty ballista decided not to work normally.
It starts normally and cant exceed 1/4 throttle then stalls then its hard to start.
Then when its cool its easy to start but sometimes i can go past 1/4 throttle
So whats the problem?
yummyguts is offline   Reply With Quote
Old 01-21-2009, 10:26 AM   #2
chunk t's Avatar
Originally Posted by yummyguts View Post
Hi guys
You gave two really good clues to what is going on and you should remember them
1. engine stalls beyond 1/4, 1/2, 3/4 throttle
2. hard to start until cool.
Your high speed needle is set way too lean. back it out 3 turns from where you have it (1-turn out for each 1/4 from full throttle before the engine stumbles). Start here and richen the needle 1/4-turn at a time until it's running.
To the other end of the spectrum. If the engine spits fuel out the exhaust and will not run w/out the glow ignighter attached, you are too rich.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 01-21-2009, 11:19 AM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1 your high speed needle is way too lean. Ritchen it up like chunk t said.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 01-21-2009, 02:49 PM   #4
vladconnery's Avatar
Trader Rating: 35 (100%+)
Hi guys
Or another possible problem is because you have been running it lean. The P/S are now shot and can't hold compression. If you can with the plug in turn the fly wheel over easily then it's probably shot. Even if your getting some compression resistance is more likely because its cold and everything is tight. When it warms up it the sleeve expands and it dies again. Making it difficult to start until it cools. Even when you get it started it dies out quickly because its way warn and does not take much heat for it expand beyond the limits of a good seal.
This does not mean that that's whats wrong however it's another possibility. How old is the engine in gallons through?
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 01-21-2009, 02:57 PM   #5
chunk t's Avatar
Vlad,
Good point. If the needle IS correct a loose back plate or blow-bye on the P/S can generate similar irratic running habbits.
B-Mod Tunnels
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
FEMCA 1/10th and 1/8th Onroad Championship Danny Teh Malaysian R/C Racers 152 09-07-2008 08:49 PM
The future of RC? - New Radio Technology stuff Electric On-Road 275 11-09-2005 12:49 PM
Newb with rs4 woes rivbluenoma Rookie Zone 10 07-18-2005 09:39 PM
