Old 01-20-2009, 12:37 PM   #1
Default High Idle after WOT
I have CEN Genesis GST 7.7 running a Corsa .46 motor with a 20% fuel mix. After I hit WOT the engine still screams! I've checked the carb and it does return to idle but it still acts like it's on WOT! What gives? Also, I tried setting the LSN a little richer and the engine eventually calms down after WOT (takes about 15-20 sec) but then after about 2 min the engine dies!! Also, if I try leaning out the HSN the engines runs fill e but after about 7-10 min of Sunni g the enigine looses power and no longer goes Fast even at WOT! I need help!?!?!
ChicoRCKing is offline   Reply With Quote
Old 01-20-2009, 12:45 PM   #2
Dalepad's Avatar
It sounds like the the engine is too lean to me. Take and fatting the master needle and see what it does.
Dalepad is offline   Reply With Quote
Old 01-20-2009, 12:46 PM   #3
Gliptal's Avatar
sounds like HSN too lean and LSN to rich. When it looses power is it overheating, whats the temps?
Gliptal is offline   Reply With Quote
Old 01-20-2009, 01:35 PM   #4
slaytanic's Avatar
Trader Rating: 20 (95%+)
Check your idle gap. Could be to big causing you to lean the LSN to compensate.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 01-20-2009, 01:50 PM   #5
I almost agree. Idle speed (gap) is set to high and the LSN is set too "rich" to compensate.
A linkage binding or servo problem can cause a simialar problem so be sure it's not a mechanical problem before you start turning needles
John Schafer is offline   Reply With Quote
Old 01-20-2009, 05:23 PM   #6
Trader Rating: 171 (100%+)
It sounds too lean, but I would check to see if the servo is not causing the issue, I had one that would not return to neutral and it would not show up till running the truggy for a few minutes and secondly I would check the carb? is it a slide, if so check to see if it is moving smoothly and not binding, I again had one that would bind up after warming up and then go away after it cooled down, that is very frustrating
Troubles Dad is offline   Reply With Quote
Old 01-20-2009, 06:35 PM   #7
RETRO RC's Avatar
+1 and idle set to high to compensate for the rich LSN.
whats happening is when you do a WOT run then stop, the engine over revs as you have cleared out the build up of fuel due to the rich bottom end, as the bottom loads up again you idle drops back to normal.
check your Idle gap is between .7 and 1mm get you engine up to temp richen your top end by about 1/2 a turn lean your bottom end so that the buggy takes off with out bogging then fine tune from there.
adrian
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 01-20-2009, 08:10 PM   #8
True. My idle gap does seem a little wide but... A 1mm gap I'd soooooo small. I look at a ruler and my gap is about 1cm. How big is 1mm?? Barely open at all? Then if I lower the gap... I also have to lean out the LSN... Correct?
Old 01-20-2009, 08:12 PM   #9
Yes the engine dies overheat. Hot enough the sizzle a drop of water like a frying pan sizzles fried eggs...
Any suggestions?
Old 01-20-2009, 08:13 PM   #10
waaaaayyyyyy too lean on the top
B_Wheeler is offline   Reply With Quote
Old 01-20-2009, 08:15 PM   #11
CJ RC's Avatar
lol 1cm? thats 10mm
______________________________________________________
| ABSOLUTE HOBBYZ | AKA | HB RACING | OS | KO PROPO |
CJ RC is offline   Reply With Quote
Old 01-20-2009, 08:48 PM   #12
Tree's Avatar
Send a message via ICQ to Tree
I would set the needles back to factory settings. Check the idle gap. Make sure that it is no more than 1mm when neutral. Once your idle gap is set retune your mill for performance. If you are still having problems you might have a leak somewhere.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 01-20-2009, 10:11 PM   #13
That's correct.
As Tree said, it would be a good idea to reset the carb to factory/beak-in settings and re-tune from there.
Novarossi engines thread EVOLUTION Onroad Nitro Engine Zone 5360 08-14-2017 11:48 PM
Piks of your MEAN truck!!! ProudSavageOwnr Monster Trucks 2536 02-24-2017 07:01 AM
DAVAO CITY R/C CLUB bash n thrash Manila Racers 1215 02-10-2015 07:20 AM
Cyrul's Break in Procedures revzalot Onroad Nitro Engine Zone 156 03-21-2012 02:47 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
