Old 01-21-2009, 07:07 AM   #16
last's Avatar
Originally Posted by motoclay View Post
+1
haha, thats why i retracted my previous post, i was kinda being a smart ass about everyone putting grease in the diff. That makes absolutely no sense hahaha. Those spider gears run in thick oil all the time. Putting grease in there would just make a mess. And on the ring and pinion you can only use so much, most of it is squished out almost immediately anyway.
no I meant ring and pinion. I have an X2 and they call it the bevel gear. I've looked around though and it always says grease. I was just curious because of the plastics involved I know some auto grease will eat at plastics and others will make seals swell and/or disolve. I thought it was an important place of wear and there didn't seem to be much literature on it.
I was using axle grease (the red stuff) and was wondering about viscosity and grit issues.
This turned into a good thread though.
Someone's got to be Last
***Team Terribles***Answer RC USA/Torco Race fuel
last is offline   Reply With Quote
Old 01-21-2009, 09:14 AM   #17
any grease that is high temp, high tensile strength is what i would use. No graphite or his speed or ne thing like that. Mystic makes some good stuff, also Lucas.
In Fact, we got some high temp lucas grease, it was like 5 bux or something for the tube for a gun. We packed clutch bell bearings with it, those bearings just keep goin and goin.
I wish the diff cases were sealed with O-ring type seals so you could actually run the gears in oil as well. Oil and grease packed metal parts will run forever. Ie. the spider gears in the diff. I dont even see how they could EVER wear just completely out. The plastic cup will go before the spiders and pins.
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 01-21-2009, 09:22 AM   #18
t0adman's Avatar
Phil Wood waterproof (duh) bicycle grease works great for me.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Old 01-21-2009, 01:51 PM   #19
heeltoedrver's Avatar
a long while back i had a rc18t and it came with some associated "black grease" will this work? its a tiny tube but if i can use it might as well right?
Team Terribles
heeltoedrver is offline   Reply With Quote
Old 01-21-2009, 02:49 PM   #20
Trader Rating: 66 (99%+)
Originally Posted by Jaz240 View Post
Mobile synthetic, buy it at any auto shop, its a red paste, comes in a tub, $6, enough for life!
.....I use it on ring/pinion gears
pwnzor is offline   Reply With Quote
Old 01-21-2009, 02:59 PM   #21
madmaxx's Avatar
that's what i use! came with my Robinson Racing gear's.....
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 01-21-2009, 09:56 PM   #22
sugs's Avatar
Yup, Associated Black grease for me too. Don't even remember how long ago I bought it. Probably back when I was racing 2wd electric. Can you still get it?
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 01-22-2009, 08:47 AM   #23
sidewaze's Avatar
I use Lucas Red N Tacky
Team Novak tech@teamnovak.com | Pinnacle Freight Specialists www.pinnaclefreight.ca
Trick Parts Trick-Parts.com Stainless Steel screw kits lifetime warranty
Xray T3'11 Havoc Pro SC/17.5 Ballistic| Xray T2'008 Havoc Pro SC/21.5 Balistic CVTA
WGT CRC Gen-X 10LE Havoc Pro SC/17.5 Ballistic| CRC GenX Havoc Pro SC/17.5 Ballistic
Action Hobbies Kingsville | Lou's Speedway Dorchester www.lousspeedway.com
sidewaze is offline   Reply With Quote
Old 01-22-2009, 08:48 AM   #24
i have no idea if you can still get it or not, and honestly im not going to go looking either, not when i can go to the local hardware shop and get enough to last 3 lifetimes for like 5 bucks.
Team Terribles
Old 01-22-2009, 09:11 AM   #25
Ill second that. The "hobby specific" stuff is most of the time repackaged, relabled and overpriced items you can get at a much larger value somewhere else.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 01-22-2009, 05:21 PM   #26
cweb's Avatar
Trader Rating: 35 (100%+)
I used ureka pro lube all last season and it worked great. It is a little pricey for that tube. Got a big 1 lb tub of mobile 1 synthetic grease at pepboys for about 9 bucks,I use it in the bearings. I may try that on the ring and pinion juist for kicks.
Team Whiteknuckle- CW
B5M- viper-rc/Hitec/avid/schelle/mip/protek-rc/lunsford
T5m- viper-rc/Hitec/avid/schelle/protek-rc/lunsford
cweb is offline   Reply With Quote
Old 01-22-2009, 11:47 PM   #27
sugs's Avatar
Sorry guys, I was just curious if Associated still sells it, wasn't suggesting to go out and get it. I'm sure it's just repackaged automototive lube of some sort.
Old 01-23-2009, 01:38 AM   #28
No apology needed here buddy. I was just offering some friendly advice to help save you a little dough. Im sure the other dude was doin the same.
Old 01-23-2009, 06:45 AM   #29
trerc's Avatar
Trader Rating: 89 (100%+)
Yes Associated still sells it (ASC 6588). I like it, I mean its like only 2 bucks a tube and a lot easier to keep in your toolbox than the tub o grease.
trerc is offline   Reply With Quote
Old 01-24-2009, 07:11 AM   #30
TonysScrews's Avatar
For the ring & pinion use a small dab of black moly grease. You can pick up a small tube at any auto parts store for a few dollars and it'll last a long time. For the diffs (out drives, o-rings, etc) at the same auto parts store you can get a tube of Mobil 1 synthetic grease that'll last you a lifetime.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Inferno MP9 thread captain america Nitro Off-Road 20015 05-19-2017 02:14 AM
DF-03 MS build pics and racing progress T Fears Electric Off-Road 24 05-03-2010 06:36 PM
mbx,mbx5r,mbx5t Leaky diffs Gen Nitro Off-Road 17 02-27-2008 06:48 PM
What Does everyone think of the TB-O2?? catchm3srt Electric On-Road 29 04-05-2007 10:24 PM
