Old 01-19-2009, 02:01 PM   #1
heeltoedrver's Avatar
Default 8B Gear Mesh
how am i supposed to set the gear mesh on a losi 8B properly so that the clutch bell bearings dont blow every other time at the track? i have been using the paper method but after some research on here have discovered that this is not the way to do it so: anyone have step by step instructions? thanks!
Team Terribles
heeltoedrver is offline   Reply With Quote
Old 01-19-2009, 02:03 PM   #2
MikeFriery's Avatar
Trader Rating: 19 (100%+)
the motor not being straight is what causes the clutch bell bearings to prematurely blow out.
You can still use the paper method, but just make sure the engine is straight at the same time.
The best way to do that is to look at the screws on the bottom of the chassis and make sure they are symmetrical.
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 01-19-2009, 02:36 PM   #3
wb-racer-ace's Avatar
Trader Rating: 28 (100%+)
Send a message via Yahoo to wb-racer-ace
best way to get the motor straight is use one of my motor mounts, has bosses on the bottom that drop into the chassis slots. straight everytime!
the pics are before anodize, have some available in black anodize also, $40 shipped with an extra set of risers, I will post pics of the black mounts tonight
ADVANCED CUSTOM ENGINEERING.....custom components designed for racers, by racers!!!!! email acercparts@yahoo.com for info
http://photobucket.com/acercparts
email [email]acercparts@yahoo.com[/email] for info
[URL=http://s811.photobucket.com/albums/zz37/acercparts/]ACE Products Click Here[/URL]
wb-racer-ace is offline   Reply With Quote
Old 01-19-2009, 02:38 PM   #4
vladconnery's Avatar
Trader Rating: 35 (100%+)
1st. Make sure CB is shimmed properly. No more than a shims worth of play.
2nd. Engine needs to be in a straight line. As well as properly meshed.
3rd. If you have done all of this you may need to take into consideration. Your getting to much chassis flex. A Kings Head extended motor mount will solve this problem as well. I don't use one and I don't have CB bearing issues.
4th. You may one to consider a Losi 1 piece motor mount. Once you get it set you never need to move it again unless you go up or down in CB size.
A cocked engine will eat your bearings as well. Worn engine bearings. Worn engine bearing orifice will do the same (where bearing sits in engine). Poorly meshed CB will do the same. Check your bearings in the center diff mount.
Once you set your mesh roll the buggy on the floor. There should not be any strange noises.
Once you have all of the above checked and in order $1 bearings. Will last you quite a while. Don't believe the hype $8 bearings not going to make a hill of beans difference. If any of the above are out whack.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 01-19-2009, 03:52 PM   #5
pics of anodized mounts
8B Gear Mesh-8ightmount1-600-x-451-.jpg   8B Gear Mesh-8ightmount3-600-x-451-.jpg
Old 01-19-2009, 03:59 PM   #6
does your mount work with both bump start and roto start engines???
Team Terribles
Old 01-19-2009, 04:00 PM   #7
does not work with roto-start, but I can make one
Old 01-20-2009, 09:25 AM   #8
yaright's Avatar
Do you have a or any plans for a extended version?
Losi 8ight T 2.0.....PRO TWISTER MODS GO 25 6 Port / GRP
DX3R JR 9100t & 8800t
J-DUB HUBZ
Losi 8ight.....Dynamite Platinum 21XP..........JR8800T's
www.trackseekers.com
yaright is offline   Reply With Quote
Old 01-20-2009, 12:07 PM   #9
yes I do, in fact I have one drawn up that is going into the machine this weekend
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 01:30 PM
8t gears in a 8b? jrwoodchuck Nitro Off-Road 34 06-06-2009 10:25 AM
