Old 01-19-2009, 02:46 PM   #16
Garen, I agree with you. I have the Fioroni Diffs and alot of other upgrades. The Diffs do work and you are EXACTLY right, they are a Tuning option. In some cases that I have ran them, the buggy was a damn bullet!! I use the front and center.
I get tired of hearing, "thats way to expensive", "you wasted your money" blah, blah, blah. It's my money!!! Nobody is forcing anyone to buy them. Fioroni is not ripping people off. Fioroni is NOT crap out of Taiwan.
SPEEDSKI is offline   Reply With Quote
Old 01-19-2009, 07:52 PM   #17
Trader Rating: 7 (89%+)
As I have seen it here in the Philippines. Its something I would put my money on. BTW is it thesame as Active diffs for an 808? I am looking to buy 1.
oggietiu is offline   Reply With Quote
Old 01-19-2009, 08:11 PM   #18
fast11970's Avatar
Will The kysho or other diff Fit in the Jammin X2? I have heard good things about these diffs, an think it might help my X2 in certain conditions, My main complaint is too much over rotation when turning on power, does anyone think that running this type of diff in the front will help?
I have covered all the standard set up changes...right now 5-5-2 is working well, but not optimal.
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 01-19-2009, 08:43 PM   #19
garen's Avatar
I know the Kyosho diffs and pinion gear fit in my OFNA DM-1 GT car, and that car uses the same diffs as the Jammin X1, so if your X2 uses the same diffs as the X1, it should fit. You might want to double check that with someone else though.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 01-19-2009, 08:46 PM   #20
fast11970's Avatar
Uses the CRT X2 Diffs, Well At least the Ring an Pinion.
MBX6
Old 02-24-2009, 06:30 PM   #21
BrettL's Avatar
Trader Rating: 21 (100%+)
Send a message via Yahoo to BrettL
Default Money Well Spent
I drove my Fioroni modded Storm for the 2nd time today, the first on a track. I agree now that my Storm Center Traction diff, although several model years old, would still be worth the money. It made my Storm much more driveable on a bone-dry track. I think with a properly wetted track this car will be awesome with this diff in the center. I'll post again when I've ran it on a good, wetted track and tell you how it does compared to my old, stock Storm.
BrettL is offline   Reply With Quote
Old 02-25-2009, 04:13 AM   #22
Shane Racer's Avatar
Garen, What track conditions should the diffs be used on.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 04-14-2011, 01:51 PM   #23
R.MOSLEY's Avatar
Send a message via ICQ to R.MOSLEY
+1?
Ryan Fox Mosley
Team Mugen Seiki
R.MOSLEY is offline   Reply With Quote
Old 04-15-2011, 01:49 AM   #24
triplesix's Avatar
years ago, i've been using a front torsen diff in my mugen mbx-5
it wasn't a fioroni but a nuova faor - price was about the same
since this car was heavy like a tank and didn't steer too well into corners compared to others, the torsen diff really helped in dialing in some agility.
the car would steer into corners very well and coming out of corners one could jam the throttle and when the diff locked up, it pulled the car right out of the turns. on the other hand it needed a much smoother driving style (less blipping the throttle), since blipping made the diff to load/unload permanently which made the car inconsistent and nervous.
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 04-15-2011, 07:46 AM   #25
garen's Avatar
The diffs make the car more responsive so on a blown out rutted track the car may become nervous as the car will feel like it has more 'punch' and response. On smoother tracks they work great and on tight tracks they work great. Having said that, I have seen them used on very rough surfaces and the drivers were very happy, so I guess the answer is you have to try on a variety of surfaces and see where they provide an advantage for you.
N.a.s.c.a.r chammond Canadian R/C Scene 9560 08-06-2017 04:38 PM
GS Storm and Storm Cl-1 Thread BrettL Nitro Off-Road 316 07-23-2017 01:00 AM
Torsen center diff CaptCrunch Nitro Off-Road 6 06-16-2009 10:13 AM
$225 for a diff? Seriously? Don Duct Nitro Off-Road 69 10-15-2008 04:33 AM
Kyosho SP1 Roller With Fioroni & KHZ Parts Ephidelt490 R/C Items: For Sale/Trade 33 01-22-2006 06:56 PM
