Old 01-18-2009, 01:56 PM   #1
Default mugen mbx6 rear captured hinge pin toe block system
MUGEN MBX6 REAR TOE BLOCK SYSTEM SKU 5700
MADE 7075 AIRCRAFT ALUMINUM FOR MAXIMIUM STRENGTH. THEY ARE A CAPTURED HINGE PIN SYSTEM WHICH MAKES
CHANGING THE TOE SIMPLY REMOVING 2 SCREWS ON THE BACK AND
LOOSING THE 2 BOTTOM SCREWS. THE USE OF THE TAPERED BALL HINGE PIN GIVES THE USER A VERY FREE FLOATING SYSTEM THAT WILL
IF A CRASH IS BAD ENOUGH TO BEND THE HINGE PIN THE SYSTEM WILL
CONTINUE TO OPERATE FREELY AS THE BALL CAN STILL ROTATE IN THE BUSHING OR THE ARM CAN ROTATE AROUND THE HINGE PIN.
IF THE PIN DOES GET BENT IT WILL LIKELY OCCUR AT THE WEAKEST POINT ON THE PIN WHICH IS AT THE BOTTOM OF THE TAPER.
THIS AREA IS NOT IN THE BUSHING OR IN THE ARM , ALLOWING THE
SYSTEM TO STILL FUCNTION.
When you order off my website, I will engrave you name or nick name on the rear blocks
FREE
KIT COMES WITH :
(C) BLOCK
(2.5) TOE BLOCK
(3.0) TOE BLOCK
(2) 2 HINGE PINS
(1) 1 PK. ASS. BUSHINGS PART NO. 89039
(4) 1/4 DEGREE CUSTOM BUSHINGS PART NO. 3900
m2cracing is offline   Reply With Quote
Old 01-18-2009, 08:15 PM   #2
Looks like a great product ... can you post the web address?
glolar is offline   Reply With Quote
Old 01-18-2009, 10:24 PM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
www.m2cracing.com
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 01-19-2009, 02:00 AM   #4
Default product
looks a great product but 70$ seems abit too much
muaythai is offline   Reply With Quote
