Old 01-17-2009, 08:03 AM   #1
8&stuff's Avatar
Trader Rating: 55 (100%+)
Default heat gun/break-run-in
Im a year into nitro. iv had lots of help learning and still have a ways to go to be as smart as some. iv used many methods for break in and had some mis haps. lately things have been good on break in but i see lot of changes that iv made from the 1st engine iv broke in(w/help)to the engines im running in at the moment. my question is, how many people use a heat gun to heat the crank case up for the 1st start and maybe up through the first gallon? i had a pretty bad arguement w/an old freind thats been breaking in engines for 20+years about not heating engines up w/heat gun to start during break in. the engine in particular was an old resized, new bearings&rod mr ninja 21. all input is greatly appreciated.
Mark Buecker
8&stuff is offline   Reply With Quote
Old 01-17-2009, 08:21 AM   #2
Mark_Australia's Avatar
Well some engines need it as they simply will not turn over otherwise (too tight).
Others u can pull start easily - in a RTR for example.
Therefore you don't know just how tight it will be and how bad it will scrape the bore or if you will stress out the conrod heaps.
So I'd say always preheat a new motor to be safe.... can't hurt it by heating when unnecessary!
I've had some that were so tight (and you don't know till you try) that I had to put heaps of oil in and preheat then run on the starter box with no plug in, cos preheat plus oil and it wtill would not turn over with a plug in. Now I just figure I will always spin them up hot and slippery with no plug for a min or so before I even try to start it
Mark_Australia is offline   Reply With Quote
Old 01-17-2009, 08:44 AM   #3
Trader Rating: 36 (100%+)
I always preheat along with after-run oil. I do it even after break-in when the temp is below 60F. It saves a lot of stress on the con rod and gets you past that warm-up stage faster.
Sabre X3 V2
Losi 8ight 2.0
Losi 8ight 2.0 e
rstnboy is offline   Reply With Quote
Old 01-17-2009, 08:44 AM   #4
preheating greatly reduces stress on racing engines, it helps the sleeve to expand to its optimum fit faster (reducing wear) it will keep your conrod happy too!
RHF Raceway Track Manager
Kyosho MP-9
Futaba 3PK
C6BBT/WS7
Kyosho ZX5
avbrando is offline   Reply With Quote
Old 01-17-2009, 08:58 AM   #5
Trader Rating: 61 (100%+)
preheat at least for the first gallon during break in ....it reduces cold crank stress when starting the motor up
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 01-17-2009, 09:11 AM   #6
Suspended
+1
Preheating makes hard to start engines a little less bitchy, and it makes easy to start engines just that much easier.
There really is no valid argument against doing it.
Wes Briscoe is offline   Reply With Quote
Old 01-17-2009, 09:12 AM   #7
jasandsrc8's Avatar
You need a heat gun to help with the heat cycle during break-in. You have to keep the engine really rich during this cycle, thus the engine will not heat up enough. You need to get it up to 180-185 during break-in and try to keep it there during this process. This is the best break-in process I have found.
jasandsrc8 is offline   Reply With Quote
Old 01-17-2009, 09:32 AM   #8
LabRat99's Avatar
I use a cheapo heat gun that I bought from Harbor Freight for ten bucks. I use that on new engines along with heat cycling to break them in.
As somebody else posted above, it can't hurt and it's probably easier on the rod.
LabRat99 is offline   Reply With Quote
Old 01-17-2009, 09:48 AM   #9
im new to this whole game and my ninja is almost here. i have never heard about using a heat gun, how do you do this exactly?
ajhaun is offline   Reply With Quote
Old 01-17-2009, 09:49 AM   #10
omarwashington's Avatar
I would think that each and everytime you start the engine, even after break in would help the longevity of the engine and not put so much stress on the con rod.
omarwashington is offline   Reply With Quote
Old 01-17-2009, 09:50 AM   #11
BOOST's Avatar
So why argue with someone who has '20+' years experience??? If you don't want to take the advice and learn a thing or two then go ahead and do it your way and find out the hard way!!!
BOOST is offline   Reply With Quote
Old 01-17-2009, 10:58 AM   #12
That same logic would mean we would still be using rattles and chanting over the sick and infirm. Instead, those disciplines have improved...such is the case here. The science behind why pre-heating is beneficial has already been described in the thread by others (no need to repeat it) and it is sound advice.
Sabre X3 V2
Losi 8ight 2.0
Losi 8ight 2.0 e
Old 01-17-2009, 11:16 AM   #13
jasandsrc8's Avatar
Simply heat up the side of the engine with the gun. Keep in mind it heats up pretty quick. Heat cycling has worked for me. I will use this method everytime I break-in a new engine.
Old 01-17-2009, 12:01 PM   #14
ok how long do u heat it up for like 30 seconds or five minutes?
Old 01-17-2009, 12:16 PM   #15
jasandsrc8's Avatar
If you would have looked at my other post you would have your answer. Pay Attention!
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
Team Losi XXX-T CR, What are yours opinions ? Jason Pelletier Electric Off-Road 2231 01-19-2012 09:16 PM
Flywheel nut help! jhipps835 Nitro Off-Road 19 08-04-2009 02:46 PM
Locktite Removal? aaron2u Nitro Off-Road 10 02-22-2009 04:42 PM
