heat gun/break-run-in
Im a year into nitro. iv had lots of help learning and still have a ways to go to be as smart as some. iv used many methods for break in and had some mis haps. lately things have been good on break in but i see lot of changes that iv made from the 1st engine iv broke in(w/help)to the engines im running in at the moment. my question is, how many people use a heat gun to heat the crank case up for the 1st start and maybe up through the first gallon? i had a pretty bad arguement w/an old freind thats been breaking in engines for 20+years about not heating engines up w/heat gun to start during break in. the engine in particular was an old resized, new bearings&rod mr ninja 21. all input is greatly appreciated.
Well some engines need it as they simply will not turn over otherwise (too tight).
Others u can pull start easily - in a RTR for example.
Therefore you don't know just how tight it will be and how bad it will scrape the bore or if you will stress out the conrod heaps.
So I'd say always preheat a new motor to be safe.... can't hurt it by heating when unnecessary!
I've had some that were so tight (and you don't know till you try) that I had to put heaps of oil in and preheat then run on the starter box with no plug in, cos preheat plus oil and it wtill would not turn over with a plug in. Now I just figure I will always spin them up hot and slippery with no plug for a min or so before I even try to start it
Preheating makes hard to start engines a little less bitchy, and it makes easy to start engines just that much easier.
There really is no valid argument against doing it.
You need a heat gun to help with the heat cycle during break-in. You have to keep the engine really rich during this cycle, thus the engine will not heat up enough. You need to get it up to 180-185 during break-in and try to keep it there during this process. This is the best break-in process I have found.
I use a cheapo heat gun that I bought from Harbor Freight for ten bucks. I use that on new engines along with heat cycling to break them in.
As somebody else posted above, it can't hurt and it's probably easier on the rod.
im new to this whole game and my ninja is almost here. i have never heard about using a heat gun, how do you do this exactly?
That same logic would mean we would still be using rattles and chanting over the sick and infirm. Instead, those disciplines have improved...such is the case here. The science behind why pre-heating is beneficial has already been described in the thread by others (no need to repeat it) and it is sound advice.
Simply heat up the side of the engine with the gun. Keep in mind it heats up pretty quick. Heat cycling has worked for me. I will use this method everytime I break-in a new engine.
ok how long do u heat it up for like 30 seconds or five minutes?
If you would have looked at my other post you would have your answer. Pay Attention!
