Old 01-15-2009, 04:43 PM   #1
mini696's Avatar
Default Stripped plastic parts (metal screw into plastic diffcase)
How can I repair/improve the grip of a screw that has stripped the plastic from its seating?
mini696 is offline   Reply With Quote
Old 01-15-2009, 04:47 PM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
you can use a little CA glue in the hole for a temporary fix.... the fix is just that temporary
jamminnay is offline   Reply With Quote
Old 01-15-2009, 04:56 PM   #3
scwrod's Avatar
I would want to replace the plastic.
You can use teflon tape, or a piece of a toothpick in the hole, some epoxy, bigger screw, etc...
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 01-15-2009, 04:57 PM   #4
rcjunkie3000's Avatar
Trader Rating: 94 (100%+)
Replace the plastic is the best method. You can also tap it with a larger screw.
RCJunkie3000 - Gonzo69 Paints / Lex Tyler Paints / Norcal Hobbies
http://www.rctech.net/forum/r-c-items-sale-trade/344416-rcjunkie3000s-garage-sale-batteries-escs-chargers-cars-accessories-etc.html
rcjunkie3000 is offline   Reply With Quote
Old 01-15-2009, 05:14 PM   #5
jamminnay's Avatar
replacing is the best option but a little glue can get you through the day in a pinch
Old 01-15-2009, 08:18 PM   #6
At ace hardware, home depot, etc you can buy little brass thread inserts. I have tried different brands like Threadserts but I prefer the brass ones made for wood. Basically you have to drill the hole larger and thread the insert into the plastic. It will only work where there is a lot of plastic but I have used them before in a jam with excellent results. In fact my 8T has 2 in it now that are holding the chassis to the bulk (diff gearboxes).
here is what they look like...
Larks is offline   Reply With Quote
Old 01-16-2009, 05:30 AM   #7
jamminnay's Avatar
that would be a good option if there was enough surface to drill out..
Old 01-16-2009, 07:20 AM   #8
bgbelden's Avatar
I'm gonna pick up some for back-up but i too have found out that glue is not the way to go having back up plastic is the best method.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 01-16-2009, 07:29 AM   #9
jamminnay's Avatar
+1
Old 01-16-2009, 08:26 AM   #10
Trader Rating: 47 (100%+)
Sometimes you can use a longer screw. Just don't
over tighten the longer one.
rageworks is offline   Reply With Quote
Old 11-10-2010, 07:46 AM   #11
Acill's Avatar
Trader Rating: 24 (100%+)
Send a message via ICQ to Acill Send a message via AIM to Acill
I ran into this on my losi 8ight buggy. I took some old parts and started to play with an idea. It worked very well, in fact I say it is nearly like new after getting it down.
Take some scrap from the plastic tree the parts are attached to and use a hobby knife to make shavings. Place them into a mix of thick CA or thread lock and use a tooth pick to coat the inside of the hole you need to fix with it. Get as much of the plastic shavings on the sides as you can and insert your original screw.
Taking a soldering iron touch the top of the screw head and heat it up. The shavings will melt some and fill in the threads. Let it set and your good!
Practice on a scrap part first, once you get the feel of the temp needed it will work awesome!
Associated Factory Team B4.2 | T4.2 | SC10
Tekno SCT410 Tekin 4.5
Acill is offline   Reply With Quote
Old 11-10-2010, 08:23 AM   #12
Suspended
Cover screwthreads with wax and veggie oil. Mix up JB weld and mush into hole.
Screw the screw in and let sit for 24 hours, Unscrew from part and boom. New threads that will last forever.
Storydude1 is offline   Reply With Quote
Old 11-10-2010, 08:34 AM   #13
Jomo918's Avatar
thats a pretty ingenious idea! definetly something to keep in mind for my buddies. i would just replace it but some of my friends are penny pinchers so this would be great for them.
~~~~~ Joey Morales ~~~~~
Hotbodies D8T/Spektrum
Novarossi/AKA/Futaba
Heritage RC Raceway, San Diego CA
Jomo918 is offline   Reply With Quote
