Old 01-14-2009, 09:11 AM   #1
Default 8T front end help
My 8T front end does not come up to the ride height. I reassemble all the front end. I put new springs, changed fluid, and bladders. Seems to be free in movement. And I have tried both stock and adjustable hinge pin braces using the 0 inserts on inner and outer brace. I am only getting about 27mm at extreme front. Running stock drake setup. Thanks
leumas is offline   Reply With Quote
Old 01-14-2009, 09:15 AM   #2
Suspended
Trader Rating: 440 (99%+)
Ride height is dictated by the preload on the springs. Turning the preload adjusters down will put more preload on the springs which in turns raises the ride height.
MattP is offline   Reply With Quote
Old 01-14-2009, 09:21 AM   #3
With the collars screwed all the way down still only get 33 at very front. ???
Old 01-14-2009, 09:32 AM   #4
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
are you positive that you have the correct springs on the front?
jamminnay is offline   Reply With Quote
Old 01-14-2009, 09:41 AM   #5
2.3 x 5.0 rate blacks yes. I also have the alum blocks and carriers but they are not new. Ran for one season
Old 01-14-2009, 09:49 AM   #6
Suspended
Losi recommends having your ride height set at 37mm front and 39mm rear.
You should have no problem attaining those ride heights if nothing is binding.
Take your front shocks loose from the arms and make 100% sure that the arms have a full bind free range of motion. And also check and make sure you don't have any bent front shock shafts as that will also throw off your ride height settings.
Take a pic if you can so we can see what your setup looks like.
Also at what point on the front end are you measuring from?
Should be behind the front kickup.
Old 01-14-2009, 10:11 AM   #7
try backing out the droop screws all the way.
Nevada is offline   Reply With Quote
Old 01-14-2009, 10:21 AM   #8
BOOST's Avatar
I agree...if you have done everything like you say then the droop screws would be the only other thing to check.
BOOST is offline   Reply With Quote
Old 01-14-2009, 10:32 AM   #9
jamminnay's Avatar
have you replaced the shock shafts or anything recently.. i am sure that yoiu are binding somewhere
Old 01-14-2009, 10:50 AM   #10
jbergman's Avatar
Trader Rating: 4 (83%+)
Yes i think you have to much droop dialed out
HobbyTown USA, Corona
www.DEracing.net
jbergman is offline   Reply With Quote
Old 01-14-2009, 11:31 AM   #11
Team AGAMA and VP Pro
nascarracer is offline   Reply With Quote
Old 01-14-2009, 11:58 AM   #12
The droop screws are not even touching. I pulled the schocks and the arms are free. I did find that the shocks were hanging in the arms a bit so sanded the opening some. Also both shocks seem to have a little offset to them, fliped them around. I am getting the correct height now but seems like I havent seen anyone else with the shock preload screwed all the way down could the rod ends cause that much and I have not changed shock shafts or seals but they do not leak.
Old 01-14-2009, 02:07 PM   #13
jkas10's Avatar
Trader Rating: 121 (100%+)
Internal limiters in the shocks? Limiting their full extension? I have no idea why you would have them...?
Are you running "Normal" Truggy Tires and not some smaller diameter tire? (making truck set lower to the ground...)
Is this a truck that you have been running and had previously set the correct ride height in the past, or is this a used truck that you are just now going through and checking over? Don't know, man. Pics would help.
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
NEW XRAY T2 ddesros2 Electric On-Road 5873 02-12-2012 05:56 PM
8T Track Setup Help Speed_Freak_039 Nitro Off-Road 29 01-15-2009 09:50 PM
