Old 01-15-2009, 08:42 PM   #46
Czech-it-Out's Avatar
Send a message via AIM to Czech-it-Out Send a message via MSN to Czech-it-Out
Originally Posted by Rocket42 View Post
The reason Go rods are so reasonably priced is smart manufacturing, Every .21, .25, .28 Go engine uses the same rod. That means 8 engines, 3port sport, 3 port race, 5port race, 7 port race, .25 sport, .25 race, .28 sport, .28 race. all use the same connecting rod. This allows them to mfgr. huge numbers of rods in one run, quantity drives the price down.
Smart manufacturering
Czech your argument holds no water, are you saying that Italy has superior brass (sleeve) or that there chrome is superior?
You are saying that the crankcases are cheap? I believe that O.S. crankcases probably have the worst reputation of any brand. Other then that what other material inconsistancy is there? The connecting rod, the connecting rod is designed to work in a .28 engine. The bearings are stamped Italy cause that is where they are made.
I believe we were discussing connecting rods......
Czech-it-Out Graphics
www.parmapse.com
Czech-it-Out is offline   Reply With Quote
Old 01-16-2009, 08:50 AM   #47
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
Originally Posted by ezveedub View Post
VG has a ABN sleeve (aluminum-brass-nickel)
Info from the VG Piston & Sleeve:
"Advanced Bi-Metallic Liner (ABL) cylinder liner construction
This process uses a double layer of plating material rather than
one thick layer. This helps the metal bond to the cylinder and is
more durable. Also, the plating process is more consistent,
resulting in a more precise fit between piston and sleeve
for better compression and longer life."
"Smooth is Slow, and Slow is Fast"
zJatoRad is offline   Reply With Quote
Old 01-16-2009, 09:36 AM   #48
n10cities's Avatar
Default Another vote for the Nova N21BF...
Originally Posted by jamminnay View Post
the rossi t21bf is an awesome motor... it is much easier to tune then the GO motors as far as i am concerned
+1 on the N21BF. Ran one all last summer with no problems whatsoever. VERY easy to tune, reliable, and Cheap!
The RB engines would be another good choice. Most of our racers run them around here and claim they are very long lasting. I would have gotten one myself, but we ran out at the hobby shop. So I had to get the Nova.
Should not be disappointed with either choice.....
Your arrogance blinds you.....
Losi - Spektrum - Byron's Fuel - Airtronics
Robbie
GSHobby.com
n10cities is offline   Reply With Quote
Old 01-16-2009, 09:49 AM   #49
MIKESRCSTORE's Avatar
Originally Posted by NitroLuver View Post
Id say if you want a decently priced motor with good performance the novarossi N21BF 3 port gets it done in both buggy and truggy( has respectable bottom and good top...but best of all it's not overpowering)...I'd run a jp-3 on this engine and an NR6(novarossi 6 which is medium) go tech's are also great engines but for the price pesonally i'd run a nova 3 port and if you wanna get a little more let Brian of PTM(Pro Twister Mods) mod it...then you'll have a sure fire screamer...good luck on your purchase
this is a good point it is easyer to drive less power better and fast than to drive way to much power faster but much slower
fast motor are for very good fast drive
you will know when the motor is just too much mikel
MUGEN MBX7 MBX7T MBX7 ECO
FUSION X3 FUSION X5 NINJA 2
DRIVEN AND POWERED BY A NINJA
EXTREME HOBBIES WERKS RACING FUEL
H.E.S. AIRTRONICS M12 HITEC SERVOS
MIKESRCSTORE is offline   Reply With Quote
Old 01-16-2009, 10:11 AM   #50
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Thats O.S. terms to scrammble out the ABN constuction of the sleeve (trying to hide the nickel part)
"The plated sleeve itself utilizes what O.S. calls an Advanced Bi-Metallic Liner, or ABL. This designates a process that uses dual plating layers of a nickel composite plating, combined with silicon carbide, instead of the single layer chrome that's more commonly seen with most motors. The benefit of this process is that the plating is more precise, providing a longer life and better seal between the piston and sleeve. This results in much more compression as well."
The above statement sums up the actual sleeve ABL/ABN subject.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-16-2009, 10:13 AM   #51
HulkNT1's Avatar
Does one need a regulate for lipo in a start box when using lipo??
HulkNT1 is offline   Reply With Quote
Old 01-16-2009, 10:17 AM   #52
ezveedub's Avatar
No, unless you strap a LiPo over 14.8, which is not suited for the starter box anyway. Your just spinning motors in the box.
Old 01-16-2009, 02:34 PM   #53
Trader Rating: 19 (100%+)
My current Go engine is the .21 5 port it has 2.5 gallons on it and doesnt show any wear on the rod or pin. It is modified but in truggy I was pulling away from OS .28xz and V-specs every week. People are scared of them because they arent $400, I am very happy with it and my next engine will be a GO.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 01-16-2009, 06:40 PM   #54
Trader Rating: 26 (100%+)
Are .21 size motors better than the .28's for truggy? It seems that most of the suggestions are for the smaller motors, why?
racerj3 is offline   Reply With Quote
Old 01-16-2009, 06:44 PM   #55
Also what clutches are reliable for these types of cars? Do I want 3, 4, or I have even seen a 6 shoe clutch on some sites. What's good?
Old 01-16-2009, 06:46 PM   #56
ezveedub's Avatar
Fuel economy and control. The .28 usually is overkill now with race truggies, since they are now fully designed & lightweight, not buggies converted to overweight trucks like in the past.
Old 01-16-2009, 07:05 PM   #57
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Zerodefect View Post
I'd avoid:
GO (cheap, but not as cheap as the RB S5&3, so whats the point)
Jammin (fuel hogs, good warranty, not as easy to tune)
GRP (fragile, and Impossible to tune)
Just stick to what you know works, what is everyone else running?
i would like to see your proof of this. if you follow what pros tell u left and right its a cinch to tune.
leave the hsn at factory and tune with the lsn. and this isnt "fragile"
the grp isnt for new racers but its a great motor.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-16-2009, 10:53 PM   #58
zJatoRad's Avatar
I see, thanks for clearing it up.
Old 01-17-2009, 04:54 AM   #59
Hi,
I am Stella and I think Orion Wasp is one of the best. I am currently working on Orion Wasp and you should try it. Thank you so much. If you found the best please let me know.
Stella
stellaf is offline   Reply With Quote
Old 01-17-2009, 05:21 AM   #60
Zerodefect's Avatar
Got a pile of GRP toast. Easy to damage carb, you need to make sure its lined up with the linkage perfectly. Seen a con-rod fly apart near the pin and kill the entire engine. ETC. I'll see if I can get a pick. I'm sure its a good motor. Best for skill level 4 racers. I've seen enough. I can't stand tuneing this engine. RB and OS are much easier. Stick to easier engines if your new. Save the GRP tuned stuff to those who really need it.
BTW, what is the factory setting? Instructions didn't say what the baseline was. Gee thanks GRP. For a while everyone was being told the wrong base settings.
I'll stick with RB/Novarossi.
Zerodefect is offline   Reply With Quote
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9307 09-20-2017 04:28 PM
R/C Stuff Wanted Kenneth Tan Singapore R/C Racers 10018 09-09-2009 07:32 AM
TUNING ,3 days in, ENOUGH ALREADY Not_A_Clue Rookie Zone 23 01-12-2008 06:11 PM
why are we still running sub-c cells?? trackpower Electric On-Road 310 12-27-2007 08:48 PM
GOOD FUEL scarlet Nitro On-Road 147 03-10-2007 08:41 AM
Considering some OFNA/CEN Buggies TxCZShooter Electric Off-Road 28 01-17-2007 07:01 AM
