Old 01-13-2009, 11:57 AM   #1
sidewaze's Avatar
Default Recommend good 8ight axle bearings
Looking to replace the axle bearings and could anyone recommend or ones to stay away from.
sidewaze is offline   Reply With Quote
Old 01-13-2009, 12:07 PM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i have always had good luck with the boca bearings.... the losi bearings are not to bad either.
jamminnay is offline   Reply With Quote
Old 01-13-2009, 12:09 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I use amainhobbies's brand protek for all my bearing needs. They are $1 a piece and last just as well as any other bearings.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 01-13-2009, 12:34 PM   #4
BOOST's Avatar
Yep you can't go wrong with PROTEK, I have used them for at least two years in both my 8 B and T. Most are $1 but some of the bigger bearings and flanged ones are a little more, but still good value.
BOOST is offline   Reply With Quote
Old 01-13-2009, 01:13 PM   #5
vladconnery's Avatar
Trader Rating: 35 (100%+)
Advantage racing 10 bearings for $9.99. Is all you need as long as your servicing your losi on regular basis. $1 bearings will be sufficient don't get caught up in ceramic this or $3 bearing that. Just a side note alot of those bearings come from the same manufacture and are rebadge under different distributors. Don't believe the hype.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 01-13-2009, 03:16 PM   #6
Send a message via AIM to housman88
go boca bearings man. they may be little pricey but they last forever. thats the only bearings i use in my 8ight.
housman88 is offline   Reply With Quote
Old 01-13-2009, 03:40 PM   #7
wallot's Avatar
dirt, water and who knows what else in offroad racing will get any bearing eventually. abec35.com - cheap bearings. metal, rubber shielded, some sizes in stainless so you dont have to worry when washing your car with water, ABEC 3 and 5 (for offroad ABEC 3 is better). been using them for couple years and they work great and yu cant beat the price.
i did have ACER set on my truggy, but most off them died after 4-5 races. They were replaced by the cheap bearings and since then i actually did not have to replace a single bearing. the got over 6 races on them.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 01-19-2009, 07:18 AM   #8
Try the ceramic type which will give you a diff experience.
rcpeople is offline   Reply With Quote
Old 01-19-2009, 07:50 AM   #9
Trader Rating: 24 (100%+)
I have always stuck with Losi bearings. Still have all of the original ones in my car that I got before the worlds so around July I think.
I think you have a lot of decent bearings that will do the job. I have used advantage or Losi..
Advantage have always been about $1 per bearing and High quality..
http://www.carolinasrc.com/Webstore/...dcategory=1545
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 01-19-2009, 08:15 AM   #10
Just courious to what kind of experience you have with baerings that cost almost $100?
RC nut is offline   Reply With Quote
Old 01-19-2009, 01:09 PM   #11
sidewaze's Avatar
Just ordered some Boca's with a rubber seal.
Team Novak tech@teamnovak.com | Pinnacle Freight Specialists www.pinnaclefreight.ca
Trick Parts Trick-Parts.com Stainless Steel screw kits lifetime warranty
Xray T3'11 Havoc Pro SC/17.5 Ballistic| Xray T2'008 Havoc Pro SC/21.5 Balistic CVTA
WGT CRC Gen-X 10LE Havoc Pro SC/17.5 Ballistic| CRC GenX Havoc Pro SC/17.5 Ballistic
Action Hobbies Kingsville | Lou's Speedway Dorchester www.lousspeedway.com
