Old 01-12-2009, 07:51 PM   #1
j_blaze14's Avatar
Trader Rating: 34 (100%+)
Default Looking for the best clutchbell bearings, bar none!
i've been trying different brands and types of bearings for a while and can't settle on 1. i know how to set mesh and how to shim the bearings but i can never get a full race day out of a set and even with a new set for a main still wonder if they will make it. i'm thinking of trying the acer bearings next, teflasonic or poly something or ceramic. so far i've tried panther m/r, ae/ ttr, racers edge, big bearings, tko, protek, and some others i can't remember. i have had sets last 2 gallons and others last a tank, just not consistent enough for me.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 01-12-2009, 07:54 PM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Did you try the Kyosho bearings? We had the best usage from those so far. The key also is the shimming and keeping about 0.3-0.4mm of CB endplay.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-12-2009, 08:33 PM   #3
Ive been using the Boca Ceramics with the Green Seals. I can get 2 full race days easy and have gone more. I just change them atleast 2 races to be safe. They are around $2.50 each, but they last longer and it isn't worth a breakdown in a Amain for a few extra bucks.
SPEEDSKI is offline   Reply With Quote
Old 01-12-2009, 08:53 PM   #4
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I dont know if these are the best hands down but I leave these in for 1 gallon at a time and never failed for 9 gallons so far...... not that expensive either
OFNAPart: 40683 special long last clutch bearings
cpaurl
rallyebmx is offline   Reply With Quote
Old 01-12-2009, 09:03 PM   #5
Danny B's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to Danny B
I run these 7804K106, I get from McMaster-Carr. They are nice, I Got 2 gallons on the current set and still going strong. Mileage will vary with clutch set-up, track conditions etc etc. i think the biggest benefit to them is they are oil filled not grease filled. Biggest draw back they are $8 each!!
Luckily, my families business orders from there and I can slide some bearing as shop supplies as part of my "sponsorship" lol
Danny B is offline   Reply With Quote
Old 01-12-2009, 09:06 PM   #6
sickboy's Avatar
Trader Rating: 72 (100%+)
You have other problems if you are going through bearings that fast. It has to be a bent crank, warped clutch bell or excessive chassis flex/bent chassis. Maybe its shimmed too tight. I use $1 Avid bearings and they last me about a gallon.
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 01-12-2009, 09:06 PM   #7
losi_racer's Avatar
Trader Rating: 25 (100%+)
i was havin clutch bearings go out after every race, i couldnt figure out why.but i ended up figuring out i had a front bearing leakin in the motor causing the pads to slip and bearings to fail. it was leakin so minimal that my tune wasnt affected. just a thought maybe thats why yours are failin
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-12-2009, 09:10 PM   #8
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Gear mesh, shimming isnt nearly as important as chassis flex....
if its all over the place no bearing is going to live
Anyway, I've run AVID stuff for years.... never had any failures. Usually my clutch is done in about a gallon and I throw some new ones in while I'm in there. Theyre only a buck a piece
Tony Newland is offline   Reply With Quote
Old 01-12-2009, 09:11 PM   #9
Yep another happy AVID user...awsum bearings, last me about 2 race meets
cm27456 is offline   Reply With Quote
Old 01-12-2009, 09:13 PM   #10
Czech-it-Out's Avatar
Send a message via AIM to Czech-it-Out Send a message via MSN to Czech-it-Out
Hard to beat Avid bearings, I have heard alot of good things about the ready rollers as well
Czech-it-Out Graphics
www.parmapse.com
Czech-it-Out is offline   Reply With Quote
Old 01-12-2009, 09:58 PM   #11
Jaz240's Avatar
Trader Rating: 52 (100%+)
+1 on the Avids. I use them in my entire buggy, and they are awesome. I swap out all my bearings after a gallon. $1 a piece VS. 5 hours of bearing cleaning and re-lube..I'll take the new bearings
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-13-2009, 03:50 AM   #12
slaytanic's Avatar
Trader Rating: 20 (95%+)
Mikey! There goes the neighborhood! Readyrollers rock! No offense to Avid but I dont buy them anymore. They are too inconsistent for me. There is a guy a ebay I think 4c hobby supply that has good stuff too.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 01-13-2009, 03:54 AM   #13
Darin Z's Avatar
+1 Avids Revolutions! and keep in mind if you have had bearings blow apart in a clutch bell, its probably best to change the bell as well, its more than likely damaged. If the bearings are aloud to rock in their seat they wont last long. The bearing should fit nice and snug and not rotate in the bell.
Darin Z is offline   Reply With Quote
Old 01-13-2009, 04:41 AM   #14
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i use boca bearings.. i have never had one fail..
jamminnay is offline   Reply With Quote
Old 01-13-2009, 04:44 AM   #15
vladconnery's Avatar
Trader Rating: 35 (100%+)
Honestly this was the best answer to your problem. It's not the bearings you have another problem somewhere. You should be able to get 1 race day atleast on your bearings whether they are avids or advantage ceramic or metal. I was having the same problem tried more expensive bearings. Nothing changed I was still blowing bearings. Finally diagnosed the problem as to much chassis flex. Added a kingshead 1 piece extended motor mount to reduce flex. Have not blown a CB bearing since. J-Blaze I know you know your stuff and have been racing for awhile. However you should look at other areas for your problem fix. $1 bearings are all you need.
I run a CB bearing eating Losi and I get a gallon out of Advantage bearings .
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
