Old 01-12-2009, 06:09 PM   #16
Originally Posted by vladconnery View Post
Front: Thinner/lighter fluid in the front differential increases off-power steering. You must be careful not togo too light as the steering will become grabby and inconsistent. If you experience this go one step heavier.
In general, thicker/heavier front differential fluid increases off-power stability and increases on-power steering.
Center: Using thinner/lighter fluid in the center differential tends to make the model easier to drive on
rough and slick tracks but allows it to unload easier under acceleration and provides less forward drive.Thicker/heavier center differential fluids offer better acceleration, increased on-power steering and lessoff-power steering. In general, using thicker center differential fluid is better on high bite and smooth tracks.
Rear: Using thinner/lighter fluid in the rear differential provides more corning traction and increases steeringresponse in the middle of the turn. Thicker/heavier fluids in the rear differential provide less steering in
the middle of the turn but greater forward traction.
So that means I would probably go to 5 in the center. It is a rough track, slick when the track is dry.
Ill go with 3 in the rear, oward traction is my highest priority.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 01-12-2009, 06:18 PM   #17
vladconnery's Avatar
Trader Rating: 35 (100%+)
Actually quite the opposite you have to much forward traction. The increased center diff wt7 added more power to the rear. Combined with the increased rear diff wt3. Made the rear diff have to much traction making it try to take over and pushing the rear out from behind the path of the front tires. Hence you kept spinning out. You can't spin out if the rear tires follow the path of the front. Also you said you like to brake and roll through the corners so you want more off power steering. You doing the exact opposite with a weight of 5-7-3. Your giving the car more on power steering and less off.
Try both and see how it works experimenting is the best way to find what works for you
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 01-12-2009, 06:27 PM   #18
Actually, it was 2 in the rear, not 3. I am NOW going to try 5-5-3 in the diffs, along with a 3 degrees toe in in the rear and see how that works. I do see your point about how it could have TOO much rear traction and slide out.
Now what would you do as far as making it more stable and easy to drive?
Old 01-12-2009, 07:02 PM   #19
Quick easy adj to take the edge off a losi is. Move your shocks on the shock towers to the inside position. Move the shocks on the arms to the outside position. This will make a losi more forgiving.
KO PROPO EURUS
Old 01-14-2009, 08:45 AM   #20
I have a few observations:
1. Tires Tires Tires, if you don't have the right tires for the track you run at you will struggle. Find out what the good drivers are using and get a set. These days you can get 4 pre-mounted tires for less than $60. It's not cheap but you can't tune your car without the right tires. Personally, I'd look at the AKA tire line as they seem to be lasting a lot longer than the Losi or Proline stuff.
2. For a base setup I'd start with the "Stable and Easy to Drive" setup listed on Losi's site. The Drake Neo setups are for tight tracks and skilled drivers. I use the Neo 08 setup at my local indoor track and the turning is very aggressive, but that's what's needed on a small indoor track. However for a Novice on a faster track it would be tough to keep control with that much steering.
3. Changing diff fluid is a good fine tuning adjustment for track changes when you already have the rest of your car sorted out to your driving style. Things like tires, front toe, and camberlink settings are big changes.
Good luck and keep it fun!
GO-RIDE.com is offline   Reply With Quote
Old 01-14-2009, 02:30 PM   #21
Thanks alot!!!
1. Im thinking of getting AKA premounted Ibeams medium. Then probalby cityblcoks up front. Whateer is the crimefighter equavelent.
2. Yea I found that out the first time I ran it. it has lots of steering, but was very hard to drive.
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
losi 8ight T conversion hound_dogs_01 Electric Off-Road 334 06-10-2009 06:45 PM
Help me with racing setup Frosty56 Nitro Off-Road 6 03-17-2009 05:05 AM
Getting started:Tip's,Trick's,Newbie's come here! xsxracing Rookie Zone 59 01-03-2009 09:57 PM
