Old 01-12-2009, 01:26 PM   #1
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Default how to change front bearing?
need help or info on changing the front bearing in a RB motor..
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 01-12-2009, 02:05 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Take off the cooling head, and the backplate. Remove the piston, sleeve, con rod, and crankshaft. Put the case in an oven at 500 for about 15 minutes to expand it. tap the front bearing and it should pop right out. Install new bearing while case is still hot. You can also use a heat gun, or a heating plate. the trick is to just get the case to expand enough to get the bearing out. If you let it cool too much you will have to reheat it to get the new bearing in..
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 01-12-2009, 02:09 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Here is RBs info on that:
http://www.rbproducts.com/mainEn.php...ncept%20engine
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-12-2009, 02:56 PM   #4
Trader Rating: 24 (100%+)
Although I agree the above mentioned heating method works, in most cases I'm never in a position to use the oven when it's time to replace the bearings.
Although nearly $150 this is a great tool to have:
http://www.carolinasrc.com/Webstore/...dproduct=10023
In less than about 5 minutes you can change both bearings track side.
Ofna has this one for a good bit cheaper, it's a little harder to use and takes much more time.
http://www.carolinasrc.com/Webstore/...idproduct=3395
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 01-12-2009, 03:18 PM   #5
t0adman's Avatar
There's a great video on YouTube of a guy swapping out bearings in a ThunderTiger engine. I followed it and did the front and back bearings in my V-Spec with little to no issue. Wish I had a link for you. Do some searching and you should find it.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Old 01-12-2009, 06:21 PM   #6
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
+1 on the baking method.. it also helps to put your crank in the freezer while your motor is baking.. that will help the bearing slide in easier
jamminnay is offline   Reply With Quote
Old 01-12-2009, 10:33 PM   #7
Jaz240's Avatar
Those tools look awesome, and well worth the money, but I was always under the impression that you need to let the crank case cool around the front bearing in order to get a tight seal. how do you accomplish this without expanding/contracting the engine?
Old 01-12-2009, 11:39 PM   #8
Bigedmond's Avatar
Trader Rating: 18 (100%+)
GRP/Losi tools all the way. Warm the case with a heat gun before you put the front bearing in. When it cools, it will be perfectly sealed.
Plus, how many tools let you change front and rear bearing in 10 minutes.
Bigedmond is offline   Reply With Quote
Old 01-13-2009, 07:06 AM   #9
Jaz, I'm sure there are 100 different methods much like engine break ins. I won't say any of them are wrong but I am just speaking of what I have done and seen done. While racing with Adam Drake and some of the other losi drivers they just pull the bearings out, and put em in and get back to racing. I have done the same thing with no issues. It's just when trackside it's hard to have a oven or some torch lying around to do all this stuff with, even more so when you travel. I like to have as little as possible
You should have zero problems if you invest in the grp tool and have to change bearings without heating. I have done it many times. At the worlds we had to run in the mud and I ruined a bearing. GRP changed it out in 5 minutes and it's still is perfect today
Hope this helps.
Old 07-09-2009, 03:06 PM   #10
Garet Jax's Avatar
Trader Rating: 91 (100%+)
Hope this helps.
Alan,
Hoping you mught have some insight into this issue. I have the GRP toolkit and it has worked flawlessly on the rear bearing, but it isn't working on the front bearing.
My engine is the stock engine in the Losi RTR 2.0 8ight Buggy. It seems the long cylinder behind the front bearing is too big for the tool. Is the stock Losi engine case not a standard size?
Thanks.
Garet Jax is offline   Reply With Quote
JP engines jasoncsc Onroad Nitro Engine Zone 1160 05-10-2017 07:19 AM
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
HACKER BRUSHLESS MOTORS ERTRACHTER Electric On-Road 503 02-28-2012 10:15 AM
Procedures for removing & replacing rear engine bearing .21 picco. Loveless Nitro On-Road 7 05-02-2008 09:07 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
