Old 01-11-2009, 10:16 PM   #1
Trader Rating: 95 (99%+)
Default Need lengths of Front & Rear Center CVD's for 1/8th buggies.
Hello all,
I'm working on a project and I need a set of center CVD driveshafts. One of them needs to be 3.5 inches long and the other needs to be 4.5 inches long.
I can also use something close to those measurments.
What I need from you guys and gals is to measure the length of your front and rear CVD's in your 1/8th buggies and truggies. If you have one that is close let me know what vehicle it is for so I can order that one.
I need the overall lenght of the assmebly.
Thanks for any and all help.
Robbie
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 01-12-2009, 05:30 AM   #2
TonysScrews's Avatar
The "original" MBX6 rear center shaft is 111mm and the updated one is 113mm (E0227). The front center MBX6 shaft is 87mm long (E0226).
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
