Old 01-07-2009, 12:41 PM   #1
Eccentric's Avatar
Default 8th Scale Spur and Dif Cup Interchangability Between Brands
I'm sure this has been covered. I couldn't find a way to phrase my search criteria so I didn't have to wade through 1,245 pages of posts to find the answer....Sorry.
Will Losi 8ight spur gears bolt onto a Hong Nor/Jammin 1/8th scale diff cup without issues? I want to try 47 and 49 tooth spurs in my quest for the perfect gearing. This is in a BCE PJX converted Jammin X1 CRT (if that matters). I can only find these tooth counts in the Losi applications (both factory Losi and RRP). I can't find Jammin/Mugen/Kyosho/HB spurs in 47 or 49 tooth. I also noticed that RRP has an 'extra wide' spur for the Losi. What (if anything) is the significance of the 'extra wide' spur?
I did find a 47 tooth spur listed for the Hyper-7 buggy. Would this work with a Hong Nor/Jammin dif cup? I realize that they're made by two completely different manufacturers, but both imported by OFNA.
Please don't ask me why I specificaly want to use 47 and 49 tooth spurs (or try to talk me into some other gear combo).
-Aaron
Dangit, when did all my favorite cars, trucks, airplanes, and engines become "vintage"???
Eccentric is offline   Reply With Quote
Old 01-07-2009, 08:46 PM   #2
Eccentric's Avatar
Nobody knows eh?
I was wondering if the Losi difs are made to SAE dimmentions while all the others are metric? Just a thought...as I don't have any Losi 8th scale experience. Ony 10th scale Losi...and they do use SAE screws...
-Aaron
Old 01-07-2009, 10:04 PM   #3
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
Losi hardware on the 8ight is indeed SAE. I doubt the diff cups and/or spurs are compatible with the Hong Nor/Jammin' stuff. Hyper stuff might, for the same reasons you mentioned.
K_B is offline   Reply With Quote
Old 01-08-2009, 11:01 AM   #4
Eccentric's Avatar
Thanks for the input. I was afraid of that.
Does anyone have a Losi 8ight or 8ight-T spur that they can compare to a Jammin/Mugen/Kyosho/Hot Bodies spur? Bolt hole spacing, dif cup mounting face, outdrive shaft hole size, and side gear face shape would be the important bits I'd imagine.
-Aaron
