Old 01-07-2009, 09:25 AM   #1
8ightisenough's Avatar
Default Tire Dismount?
i recently mounted & glued up a set of new proline buggy tires but now i want to change the foam inserts to the molded inserts. My question is if i dismount them by putting them in the oven will it ruin or damage my new tires & wheels?
8ightisenough is offline   Reply With Quote
Old 01-07-2009, 09:29 AM   #2
Danny B's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to Danny B
I've never used the oven method, but if you don't care about saving the foams, just soak the whole tire in acetone overnight. It won't hurt the tires or wheels, put it does ruin the foams...
Danny B is offline   Reply With Quote
Old 01-07-2009, 09:33 AM   #3
Steve Walters's Avatar
+1
I race at several tracks thats very easy on tires. I typically where out the foams before the tire. I have done this many times and it works perfectly. Just that the foam in the tires being soaked is trashed. Soak it for 12-24 hours, and it will come off like it was never glued.
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 01-07-2009, 09:37 AM   #4
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
if you want to save the foams and wheels and everything boil them you can save everything with that method
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-07-2009, 09:47 AM   #5
I don't care about saving these foams. Do i need to do anything after removal to the tire and wheel after in soaking in acetone. Where do i get acetone and do i delute it or not?
Old 01-07-2009, 09:50 AM   #6
t0adman's Avatar
Just make sure there's not residual material left on the wheels then prep and mount like you did the first time around.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Old 01-07-2009, 10:04 AM   #7
Home Depot or Lowes for around $15.00 a gallon in the paint department. Do not dilute.
BCE 8X8 Pro Chassis
Hitec 5995TG (S&T)
M11 & Spectrum.
Old 01-07-2009, 10:10 AM   #8
pinky2252s's Avatar
if you dont want the foams then do the acetone, but put them in a SEALED container because if you dont all the acetone will evaporate
Team Terribles
Old 01-07-2009, 10:26 AM   #9
Thanks everyone for all the replies
Old 01-07-2009, 07:57 PM   #10
mcsquish's Avatar
I have used the acetone method for years for off and on road tires. For the container I used a metal coffee can. And now the 8T 2.0 is coming out it looks like I'll be using it again.......
Just remember you'll probably get carded when you buy the acetone......
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 01-07-2009, 08:08 PM   #11
pinky2252s's Avatar
Its used to make meth
Team Terribles
Old 01-08-2009, 07:31 AM   #12
Danny B's Avatar
I acutally picked up a big glass jar(with a lid) at like Target, I will fit 6 buggy tires comfortably, Couple overnight soaks to do 3 sets...
Old 01-08-2009, 12:13 PM   #13
DeastyBoy's Avatar
Question...
Does the container have to be metal or glass??
Thinking of getting a shallow larger plastic tub, so I can do multiple truggy tires if need be...
~ deastyboy ~
PM Hobbycraft Team Driver
RC8B.2 - OS Powered F.S.
RC8.2E - Tekin/Savox/Reedy
M06 Pro - Orca/Savox/Reedy
DeastyBoy is offline   Reply With Quote
Old 01-08-2009, 01:55 PM   #14
Danny B's Avatar
Originally Posted by DeastyBoy View Post
Question...
I got the glass jar so I could store the acetone for future use. I use a gallon two or three times, when i get enough sets to dismount, etc. The stuff is $15-16 a gallon so it's not cheap.
I don't think i would store it in a plastic tub for a long period of time.
Old 01-09-2009, 01:43 PM   #15
I tried the boiling method & oven method,neither worked. I think i am going to use the Acetone method i have a question before i do.
How much Acetone do i use? Do i fill the container with Acetone over the tires & wheels then seal container.
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated Factory Team RC10R5 tyreguy Electric On-Road 871 10-16-2013 09:35 AM
tire gluing help needed...please!!! mike williams Nitro Off-Road 16 06-03-2008 06:21 PM
panther wheels????? playboy Nitro Off-Road 31 12-19-2007 12:09 AM
Which tyre warmers ratter Electric On-Road 8 07-28-2004 06:04 AM
