Tire Dismount?
#16
If the bake/boil methods arent working, your either not leaving them in long enough, or your not getting them hot enough.
Removing tires is a PITA no matter how you do it. Something that hasnt been mentioned here, is that you dont need to soak the tires in acetone. As long as the container is sealed, the acetone vapors will break down the glue, without damaging the foam. I use a clean empty 1 gallon paint can and a old worn out wheel to use as a riser so the wheels werent soaking in the acetone. I only put enough acetone in the can so that there is a inch or two of liquid in the bottom of the can. Leave them in can for 24 hours and the tires pull off like they were never glued.
I prefer the acetone method over the bake or boil technique cause with acetone, the glue turns rubbery and can be removed easily. When baked/boiled, its a little more difficult...
heres a really good thread on all the methods of removal http://www.nitroaddicts.com/forums/s...ead.php?t=1931
#17
I use a old Plastic Ice cream container with a lid. It's shouldn't take all night, but it might.
#19
So you just reglue the tire to the rubber that is already there and not on the actual plastic?
#21
boiling old tires never worked for me.
i boiled them for close to 3-4 hours...still had to rip them off the rim they didnt really clean up well afterwards either.
now acetone on the other hand...works like magic!
the tires practically fall off the rims! and they clean up almost as if they never even had tires on them in the first place.
#22
I use the oven method when removing tires and replacing foams.
The process as follows.
1st. Wait till you are alone in the house (you will stink up / smoke the house)
2nd. Heat oven to 400 deg.
3rd. Use old pizza pan cookie sheet and place all 4 wheels on sheet.
4th. After placing the wheels in the oven turn off oven and wait 15 to 20 minutes.
5th. With old oven mitts or tongs remove the wheels and break the bead.
6th. After they cool, remove the tires and foams.
7th. With a dremel and wire brush bit, remove old glue from the rims and pick off old glue from tires. (I use a old pocket knife to scrape the old glue from the tires)
Note:
If after 15 to 20 minutes the bead doesn't break (It happens) then place that one wheel back in the oven for another 10 minutes.
Clean well, replace foams and glue!!!
Note:
#23
#24
Thanks for all the info. The Acetone method worked perfect
