Old 01-05-2009, 02:47 PM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default How to charge a 12v lead acid
Im using a Thunder Power 610C to charge a 12v lead acid starter box battery
How many amps should I charge the battery with?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 01-05-2009, 02:53 PM   #2
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
I charge mine @ 12v 600mA.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 01-05-2009, 02:56 PM   #3
jrwoodchuck's Avatar
i have a wall plug in type charger for mine and it has an output of 150 mah. im sure it can handle more but i can't change the output of mine. plus a slow charge will give you longer life. it takes about 5 to 6 hours to charge mine from dead.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 01-05-2009, 03:10 PM   #4
Trader Rating: 21 (100%+)
The wall charger mine came with (Hobbico) charges at 600ma as well. My Hyperion 0610iNet charger will let you charge Pb at any rate to the charger's max of 10amps.
Starter box batts are intended to be trickle charged though and typical trickle charge rates are 1amp for motorcycle sized batteries and 2amps for car batteries. I have an expensive 1:1 charger and these are the trickle rates you're allowed by this charger.
I use a float style charger for my gel cell and it uses a 750ma charge rate and then goes into maintenance mode, so I'd advise charging at between 600-750ma and not more than 1amp.
Duster_360 is offline   Reply With Quote
Old 01-05-2009, 04:06 PM   #5
If you wanna go the cheap route or cant wait to get a charger shipped to you energizer makes a charger that charges their Ni-Mh rechargeable batteries.
The powersupply thing that goes to the wall and hooks up to the charger charges at exactly 12V/ 600Ma as needed to charge that type of battery.
I think its like $15 I had one left over since I bought a battery pack for my transmiter and didnt need the charger or the AA's no more so I cut of the plug and soldered on two alligator clips to clip on to the 12V battery terminals.
Thank you that is all.
quiklyonit is offline   Reply With Quote
R/C DIY stuff... Make it Yourself and save $$$ !!! kelfo Malaysian R/C Racers 408 01-05-2010 10:20 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
what starter box for 10th scale? BlackedOutREVO Nitro On-Road 21 07-22-2007 12:19 PM
Charging amperage and other questions tnbigdawg Rookie Zone 10 09-06-2005 01:26 PM
motor "dyno" ghoppa Electric On-Road 47 06-28-2005 06:07 PM
