Old 01-05-2009, 09:44 AM   #1
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
Default Broken hex driver tip in screw...
Any brilliant ideas on how to get this sucker out?
I got a decent deal on the car from somebody on here, so I'm not complaining. Just wondering if anybody has any ideas to pull the tip out of this sucker. I know I could slot the screw and back it out with a screwdriver, but I'd rather salvage the screw if possible.
Sorry for the crap picture...my hobby is playing with toy cars, not photography
T-BirdJunkie is offline   Reply With Quote
Old 01-05-2009, 09:47 AM   #2
t0adman's Avatar
Other than destroying the screw maybe a heavy duty magnet or some metal to metal glue? I'd just toast the screw and throw in a new one. You should have a whole mess of spares anyway.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Old 01-05-2009, 09:48 AM   #3
rcterp's Avatar
Trader Rating: 35 (100%+)
Maybe epoxy the tip of something to just the broken part you want to remove and pull it out?? Maybe drill it out (pretty precise though)?? I was going to suggest slotting it.
Let me know what you figure out, I'm sure I'll have that happen at some point.
rcterp is offline   Reply With Quote
Old 01-05-2009, 10:05 AM   #4
jpz_67's Avatar
Trader Rating: 56 (100%+)
If you are careful you can take a cutoff wheel and a dremel to make a slot through the screw and you should be able to back it out. Your concave washer will probably be trash but you should be able to get the screw out. Good luck.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 01-05-2009, 10:06 AM   #5
Thanks guys
I've broken tips in screws before, but they always left just enough to grab a hold with a pair of pliers.
Guess I'll just suck it up, hack up the screw, and deal with it:P
Old 01-05-2009, 10:48 AM   #6
if you have time and your car is not thrashed now.. go drive it ive had that happen and the tip fell out.. but if your car is in need of help now than hack that thang,,, and good luck
Garrison is offline   Reply With Quote
Old 01-05-2009, 11:01 AM   #7
Well, the problem is that it came like that in the first place (bought used)
It's been driven since then (it looks like) and has track rash on it just like the rest of the chassis.
Went ahead and busted out the dremel...these suckers are T I G H T!
Old 01-05-2009, 12:58 PM   #8
bummer
Old 01-05-2009, 01:11 PM   #9
The guy did probably use permanent loctite or something like that. If you have a small blow torch, I would try to heat localy the motor mount. Loctite start to fail over 300 c.
Mister-T is offline   Reply With Quote
Old 01-05-2009, 01:24 PM   #10
Got 'er done. To tell the truth, the only reason I messed with the engine mount is because I put the 14t bell in my cart on amain...and then when I went to finalize my order, it was on backorder! Argh! so, I just went with a 13t bell.
1.1 springs and 13 teeth...it should be a rocket on the holeshots, LOL.
Old 01-07-2009, 05:14 AM   #11
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i have has this happen a few times.. i always use the tip of a utility knife to work it out..
jamminnay is offline   Reply With Quote
Old 01-07-2009, 05:32 AM   #12
jamiekerr14's Avatar
Sod's Law! I was reading this thread yesterday.. out of interest and how to remove the broken tip ect.. 20 mins after. Went to give my buggy a big clean/Check over.. and then to find The exact same thing happend to me, As I wasnt happy with my Engine position, Tried Loosening the engine mount then to hear snap! So, now have to wait till friday night when Im back home to try and Get a dremel on it. As I tried removing it, but it to wedged in.. So may wait till I transfer my stuff into my New Chassis as my one is slightly bent... After a run away incident.. 6 months ago! Happy Days haha
jamiekerr14 is offline   Reply With Quote
Old 01-07-2009, 05:41 AM   #13
Trader Rating: 5 (86%+)
remove the 3mm engine screws (yeah, the one that holds the crankcase to the mounts) so you can take out the engine. Now remove the remaining 3 4mm engine screws. Just twist the remaining block anticlockwise, you should hear a 'click' at first. Now since the affected screws is loosened, use your creatitivity to further thread it out. Hope it helps
FM 75.710
razor_clawzz is offline   Reply With Quote
Old 01-07-2009, 05:44 AM   #14
Yea, Thanks man.. that what I was planning on doing, Now I have on order some Decent Allen Key drivers... so Will try that wa before taking the dremel onto it haha thanks
Jamie Kerr
Old 01-07-2009, 08:57 AM   #15
LOL! Sorry about bringing about some bad luck
Anybody know of a good screw kit for the MBX5R (none of that stainless crap)? all the screws in the chasssis are just absolutely trashed, and maybe half of them actually FIT a hex driver.
Razor, that would have worked quite well for me if it weren't for one of the other screws in the engine mount being boogered up too
Ofna Hyper8 stingray schmelme Nitro Off-Road 804 07-13-2011 09:45 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
"Tools of the Trade" vstrok Electric Off-Road 25 03-23-2009 02:36 PM
FS: SELLING OUT - just LOADS of stuff in here.... Mustangz R/C Items: For Sale/Trade 63 04-03-2007 08:28 PM
