Old 01-04-2009, 09:09 PM   #1
Trader Rating: 22 (100%+)
Default Clutchbell question
hi there,
i screwed up my clutch bell this weekend because i didn't use loctite, to secure the screw, that is used to hold the clutch bell...it came loose and damaged a few things...
how tight does the screw have to be. i assume that it has to be tight, but not that tight that the bell doesn't spin?! maybe my screw is too short. if it were longer, i wouldn't have had the problem, because i could have tighten it all the way...
i hope i made sense...
thanks,
G
assivaen is offline   Reply With Quote
Old 01-04-2009, 09:28 PM   #2
If you are tightening the screw and the bell gets to where it wont turn, your not shimmed right. Read the owners manual for proper guidelines for shimming. THe screw should be tight, and ther should be a shims worth of end play and the bell should spin freely. You tightening on the race of the bearing and binding it up. U ran it loose to keep the bell spinning but thats why they bell fell off. IMO!?!?
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 01-04-2009, 09:47 PM   #3
Never have used loctite afraid of if you strip out the hex head you really screwed then. From the way you are talking it's not shimmed right
pdmustgt is offline   Reply With Quote
Old 01-04-2009, 10:17 PM   #4
underway's Avatar
Trader Rating: 48 (100%+)
Like they said, tighten that screw all the way down. But with shims installed the clutchbell should still spin freely....
underway is offline   Reply With Quote
Old 01-04-2009, 10:44 PM   #5
you got it...that's what happened. i didn't know the word shimming...English is not my mother language...
thanks for the input
G
Old 01-04-2009, 10:46 PM   #6
thanks everyone for the input. i wasn't sure how long the screw has to be. but it makes sense, that it has to be long enough so its shimmed right.
i am not sure though if i have to use loctite or not?
thanks guys
G
p.s. looking to get a new clutch bell. do they all have the same inside diameter?
Old 01-04-2009, 11:54 PM   #7
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
thanks guys
G
No, they dont you must buy the one that works for your engine.
Use a small amount of loctite, i just put a small drop on the tip of the screw and screw it in. Most likely it wont get stuck but if it does you can just cut a slot in the head and use a flat head screw driver to get it out
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 01-05-2009, 12:16 AM   #8
thanks a lot...much appreciated...
G
Old 01-05-2009, 12:20 AM   #9
yeaklet4's Avatar
Trader Rating: 34 (97%+)
it depends what is your car
yeaklet4 is offline   Reply With Quote
Old 01-05-2009, 03:02 AM   #10
vladconnery's Avatar
Trader Rating: 35 (100%+)
+1 cutting a slot in the head of a hex screw is very easy with a dremmel. Then use a flathead to get the screw out. Hand tighten all the way down just a little more for good measure is all the screw needs to be no need to over tighten. Over tightening is how screw heads get stripped and heads break of in shafts. The engine spins the opposite way the screw tightens. That alone with some loctite (blue) never red. Will keep your CB securely in place. Most import is to shim it correctly.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 01-05-2009, 10:04 AM   #11
i have a muggy...
Old 01-05-2009, 10:40 AM   #12
pinky2252s's Avatar
i have a muggy...
so im guessing the losi muggy?
Team Terribles
Old 01-05-2009, 12:26 PM   #13
yes, sorry i thought there is only one muggy...i looked in the manual but cant find what the diameter is or what size clutch bell i am supposed to use...
thanks
Old 01-05-2009, 12:39 PM   #14
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
+1
jamminnay is offline   Reply With Quote
Old 01-05-2009, 12:56 PM   #15
Originally Posted by jamminnay View Post
+1
what does "+1" mean?
thanks
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
WHEELIE question on my savage 4.6... toadstool Monster Trucks 19 07-04-2006 01:07 AM
