LRP ZR 21X
#16
R/C
RESTRICTOR 7 OR 6 AND A GOOD PIPE AND 20% FUEL WOULD GIVE YOU MORE TIME AND YOUR DRIVING STYLE
O.S ENGINES ARE THE BEST I LIKE THE LRP ITS GOOD AND POWERFULL
BUT O.S I THINK FOR THE MONEY IS THE BEST AND NINJA JX EB MODIFIED FOR ME ITS THE BEST OUT THERE RIGHT KNOW AND THE SPEED
GOOD LUCK
GOOD LUCK
#17
For the best results with the LRP run only Picco Glowplugs and use a MSR 1005 pipe...as well you can remove 1 thin head shim, there is 3 shims 2 X 0.2 mm and 1 x 0.1 mm..remove the 0.1 mm shim.................these engines are very pipe sensitive, they will run good on many pipes, but they will only make big power on certain pipes, the MSR 1005 makes huge power.... also a 086 is a good choice..... I find Picco plugs make the best power and have the most consistent running characteristics....... I also run OS engines, I have a very fast modified V-Spec, however the V-Spec does not make the kind of power these Picco based engines make, the V-Spec is smoother and more efficient but it lacks the hard hitting bang of the Picco's, and if you find your OS making more bang then the Picco you may need to reconsider your Picco's setup as you may not be seeing all the motor has to offer....
#18
i might have to try the 1005 pipe and the 086, and if you remove one shim will it still be ok with 30%???
#20
#22
LRP ZR 21X Parts
I just picked up a used ZR 21X with about a gallon and a half through it, the problem is, I can't find anyone who has parts for this engine. I called AE, who is the US distributor, but they were absolutely no help.
I'm looking for O-rings, a 7mm carb insert and rear bearing.
Any suggestions on where I can find these parts or suitable alternatives, please let me know.
Thanks!
Thanks!
#23
Hi.
Old thread but what the heck
I has a NOSRAM rs .21 rr (similar to the LRP). Thats an AMAZING engine!!! Run so smooth, goooood power, VERY easy to tune (also on 16% nitro), and never flames out (knock on woods ). Runtime is a little less than a few other engines. No carb issues.
