Old 01-04-2009, 12:29 PM   #1
dishsoap's Avatar
Default Does Losi Make 15mm WHITE Shock Springs?
Does anyone know where I can purchase WHITE shock springs for my Losi 8 Buggy RTR. I can only find them for the truggy however cannot find any white springs for the buggy.
dishsoap is offline   Reply With Quote
Old 01-04-2009, 12:32 PM   #2
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Do you want fronts or rears
pink_sleeve is offline   Reply With Quote
Old 01-04-2009, 12:37 PM   #3
Fletcher6371's Avatar
LOSA5454
is the white spring for the front (will fit the 8b/8t)
LOSA5460
is the white spring for the back (will fit the 8b/8t)
These springs are a lot stiffer than the stock springs, so it will make it stiffer in the corners. might not turn as well, just warning you.
FlatBusted Racing
Dialed Inc., North Central Hobbies, Competition Heat, FUnS Racing lol
Fletcher6371 is offline   Reply With Quote
Old 01-04-2009, 12:51 PM   #4
dishsoap's Avatar
Fronts and Rears. Not racing at the track yet. I am mostly getting practice on the street. I want to get better at controling before I give racing a try.
Here is what I am planning for my set up as all of the RTR look exactly the same. Tell me what you think?
http://www.amainhobbies.com/product_...oducts_id/3873
http://www.amainhobbies.com/product_...oducts_id/3186
http://www.amainhobbies.com/product_...oducts_id/4762
http://www.amainhobbies.com/product_...ducts_id/20650
http://www.amainhobbies.com/product_...ducts_id/12299
http://www.amainhobbies.com/product_...ducts_id/12300
Old 01-04-2009, 12:53 PM   #5
dishsoap's Avatar
Fletcher
Will the reds work better than the whites.
Old 01-04-2009, 01:21 PM   #6
Part Number Size Rate Color Car Front/Rear
LOSA5450 2.3 4.1 Red T Front
LOSA5451 2.3 4.4 Silver B/T Front
LOSA5452 2.3 4.7 Green B/T Front
LOSA5453 2.3 5 Black B/T Front
LOSA5454 2.3 5.3 White T Front
LOSA5455 2.3 5.6 Grey T Front
LOSA5456 3.1 2.5 Red B/T Rear
LOSA5457 3.1 2.8 Silver B/T Rear
LOSA5458 3.1 3.1 Green B/T Rear
LOSA5459 3.1 3.4 Black T Rear
LOSA5460 3.7 3.7 White T Rear
LOSA5461 3.1 4 Gray T Rear
LOSA5462 3.7 4.3 Purple T Rear
here's a list i made up. I use Silver/Green (f/r)
Reds are almost too soft, unless you run on a very smooth, high grip track IMO
silver green is a good base set up.
FlatBusted Racing
