Old 01-04-2009, 12:27 AM   #1
Gen
Gen's Avatar
Default engine bearings ,seal change ???
just pulled my engine out of truggy its relativly new and i noticed rubber seal on front bearing a bit broken (think it broke from large washer being behind tapered cone and rubbing against ) ,i have bearings i can get seal off and i played with a wheel bearing to practice removing and installing ,and there easy off but not that easy to put on ,am using small knife and small screwdriver ,,ANY TIPS ??
Kyosho MP9 tki3
Kyosho Strr Evo
Os engines
Vp race fuel
Futaba 4pks
Gen is offline   Reply With Quote
Old 01-04-2009, 03:45 AM   #2
lowey79's Avatar
Because of the relitively low cost, if it were me i'd just replace the whole front bearing.... Otherwise, if you have a replacement seal just pick the old one out with a razor blade and push the new one in...
lowey79 is offline   Reply With Quote
Old 01-04-2009, 09:37 AM   #3
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i would go with a whole new front bearing
jamminnay is offline   Reply With Quote
Old 01-04-2009, 11:10 AM   #4
Bill Wyatt's Avatar
ditto what those guys up there said...replace the bearing all together...
and use a washer behind the collet that is not any larger in diameter than the metal race of the bearing next time...basically the washer is the same diameter as the collet
I only use a collet washer if the flywheel gets too close to the front of the motor
Bill Wyatt is offline   Reply With Quote
Old 01-04-2009, 05:37 PM   #5
lowey79's Avatar
Well actually it is sometimes better to shim your clutch bell using collet shims. Specially when using a shallow CB with curtain clutches such as the Werks Racing clutch...
Just food for thought
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
how to change front bearing? Ultraspeed84 Nitro Off-Road 9 07-09-2009 03:06 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Looking for the best clutchbell bearings, bar none! j_blaze14 Nitro Off-Road 38 01-19-2009 10:44 AM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
HUGE 950R PACKAGE FT/FS Fastburn R/C Items: For Sale/Trade 14 07-10-2006 12:05 AM
Radio Contro Racers Edmonton Off Road Racing dabalaberda Canadian R/C Scene 1605 10-23-2003 08:41 PM
