Old 01-02-2009, 11:36 AM   #1
Frank L's Avatar
Trader Rating: 148 (100%+)
Default Losi LIPO Balancer Question
I just purchased a Losi 14.8v starter box battery and I am looking to balance charge it with my hyperion eos 0606i charger. A-main sold me a balance port for thunder power type connection (click here) but the 4s port has one more pin on the connector than the balance port on the battery. Can I use this connection to balance charge the battery or is it the wrong one. I donít want any lipo induced mishaps. Any help is appreciated.
Old 01-02-2009, 12:10 PM   #2
Trader Rating: 8 (90%+)
yeah had the sme problem bought losi lipos for receiver and starterbox and hyperion charger to charge them oops. called amain the guy that answered did't have a clue to he got the charger and battery out at their shop and said, "yup there different." LOL sold my starter box battery for a HT and I was told not sure it its true but since the receiver is only 2 cels and discharges so slowly i should not have any problems charging it without the balacing it??
franklucas is offline   Reply With Quote
Old 01-02-2009, 12:24 PM   #3
Frank L's Avatar
Thanks. But I just bought the battery and its 4s so I think it needs to be balanced. Somebody must know. There has to be an adapter to balance charge it with a hyperion charger.
Old 01-02-2009, 12:49 PM   #4
jkas10's Avatar
Trader Rating: 121 (100%+)
Hey, you guys have the same name
Frank, do the pins line up? Like they are the correct balance plug type? I have two types of balance plugs - I don't know the technical terms - sorry - and I have a set of adaptors to get me from one type to the other. I can look up what brand for ya if that is the issue. Let me know. Thanks
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 01-02-2009, 01:33 PM   #5
Losi Lipo's come with a Losi style connector and only Losi chargers come with them. Losi may sell an adapter or you could make one.
Panther Tires, Novarossi, Fusion Motorsports, Fastraxx Hobbies, Answer-RC USA
mbrienzo is offline   Reply With Quote
Old 01-02-2009, 01:39 PM   #6
PTP Racing's Avatar
Losi sells balance lead adapters
http://www.tiltedrc.com/product_info...ducts_id=12658
I dont have a Hyperion charger so I cant tell you if they will plug into it though. If you get them please let me know if they work because I am interested in upgrading to the Hyperion charger.
I have a Multiplex that doesnt balance and a Mystery charger that does balance but I had to reverse polarity on those adapters to make it work.
I wish they would standarize the lipo balance connectors or at least make it easier to tell which adapts to what because its pretty confusing right now.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 01-02-2009, 02:13 PM   #7
8&stuff's Avatar
Trader Rating: 55 (100%+)
with a different charger i ran into the same issue. i called losi and they said to buy there balance converter pack losb9651(they do have one whether or not it works for you stuff)anyhow my starter box lipo was compatible but not reciever packs. luckily there were only 3 wires to the balance lead that I soldiered. i use lipo in both truggy&buggy so i had 2 batteries. my problem with soldiering was making sure that the correct wire were to be soldiered and vise versa. i took a stab at it and ended up getting them matched up correctly. pretty big confusing pain in the neck..
Mark Buecker
8&stuff is offline   Reply With Quote
Old 01-02-2009, 02:18 PM   #8
Frank L's Avatar
The pins line up and the plug locks in but there is an extra pin on the charger balance connection that is not on the battery balance port. Dont want to damage a new lipo battery.
Old 01-02-2009, 07:55 PM   #9
nitroburner65's Avatar
Trader Rating: 16 (100%+)
OH...........I thought I was in nitro off road
nitroburner65 is offline   Reply With Quote
Old 01-02-2009, 07:59 PM   #10
Frank L's Avatar
Talked to LOSI and they only know that the losi battery takes a losi balance type connector. The Hyperion charger is smart such that it knows when the battery and balancer are connected properly. The Thunder Power balance connector has 6 pins on the 4s connection, however if you plug the losi balance connector starting with the #1 pin the charger reads that the balancer is connected correctly and it works as it should. Havenít contacted Hyperion but it seems to work with the Thunder Power type connector. I have never used a Hyperion charger and it is totally quiet no noise at all. It is cold outside. Anyone know if this is normal? The display reads that it is charging, I just never had a charger that was totally quiet.
Old 01-02-2009, 08:28 PM   #11
used the hyperion charger all last season, its always quiet and has never failed me. so far so good.
Old 01-02-2009, 08:36 PM   #12
Frank L's Avatar
How do you start your off road nirto engine without a starter box?? Push start maybe??
Old 01-02-2009, 09:52 PM   #13
scwrod's Avatar
2s RX-Receiver Pack, you need to balance it.
TX- Transmitter, no need to balance.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 02-19-2009, 08:52 AM   #14
mlbright's Avatar
I have the same batteries and charger, the starter battery i had to use a adaptor to go from battery to balancer. With the RX battery I use this, http://www3.towerhobbies.com/cgi-bin...&I=LXMGS7&P=ML, it worked but dont really know if its the right way.
mlbright is offline   Reply With Quote
Old 02-19-2009, 10:57 AM   #15
Here's what I use to balance my Losi 2S Lipos.
http://www.amainhobbies.com/product_...ducts_id/10837
http://www.amainhobbies.com/product_...oducts_id/9704
ruffian is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Lipo Battery/Charger Questions jaminit Rookie Zone 8 09-09-2008 12:23 AM
What is the best lipo charger Chris08527 Electric On-Road 9 01-21-2008 11:15 AM
