Old 01-04-2009, 05:18 AM   #16
lowey79's Avatar
Originally Posted by tex1 View Post
Luck has it that Losi did a smart thing. Their new RE-11 pipe is a clone of the OS 2050 that is was discontinued. They reinforced the stinger, made the nipple welded and facing forward and improved the coating significantly. They include it with a good header and mount hardware for $65. Smoking good pipe that makes great power without loosing run time.
TEX
TEX, I don't mean to bash you here, but how reliable is this information? I only ask because i've been looking for a 2050 for a while now and if the Losi is an exact copy then i need look no further!
lowey79 is offline   Reply With Quote
Old 01-04-2009, 08:13 AM   #17
Trader Rating: 47 (100%+)
The Losi RE-11 and the O.S. 2050 look alike because
they both have the dbl welds in the center of the pipe.
We won't know if they are truly equal until one of the
engine modders does a heads up comparison on a dyno.
rageworks is offline   Reply With Quote
Old 01-04-2009, 08:34 AM   #18
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up It was a little work....
The shop I run for gets new pipes in all the time. I try and test every one of them and keep them so customers know what works and what does not before they make a purchase.
I too saw the double welds. They I used a little thought and questioned if Losi had done what I thought they had done. Very popular pipe discontinued?? I would have cloned it too.
With my 2050 sitting on the table.
I first measured the entry convergence cone. Perfect match.
I then probed the positive convergence cone. With a probe the measurements were a perfect match.
I could not measure the third chamber without cutting the pipe.
I measured through the cones holes and got a perfect match for the front of the pipe's inner walls. Perfect match.
Stinger ID matched.
Water displacement volume was the same as well.
I put it on a properly tuned Vspec in my car and just switched pipes. Not headers... OS sold the 2050 with two different headers so I used the same header for both to get the pipe comparison.
No change in tune... run temp within 2 degrees... exact same run time of 11.5minutes.
I would say it is pretty close but with better finish and damn good price to boot.
Without a Dyno this is the best I can do and share. I would like to see it on a dyno though.
Hope this helps,
TEX
tex1 is offline   Reply With Quote
Old 01-04-2009, 05:42 PM   #19
lowey79's Avatar
Thanks TEX,
I was hoping that you may have been curious enough to have done some kind of testing to compare the two.... Looks like i may be buying my first losi product very shortly
Old 01-04-2009, 07:43 PM   #20
Unsober1's Avatar
+1 on the losi pipe matching the 2050. A local racer cut opened the losi pipe and it looked to be the same. A micrometer was never used, but they appeared very similar.
Unsober1 is offline   Reply With Quote
Old 01-05-2009, 06:07 AM   #21
tex1's Avatar
Thumbs up Glad it could help....
Now I wish they would do the 2060. $160+ for a pipe is just out of the question.
A pipe I would like to study is the JP-6. These guys don't provide for what type of motor these pipes would work best on. RPM - Tourque - Fuel Milage or driving characteristics. Come on OFNA....get on the ball!
TEX
Old 01-05-2009, 06:46 AM   #22
RickBac's Avatar
Trader Rating: 20 (100%+)
I agree that matching the pipe to the engine is the main key.
For years I raced sprint/dirt and enduro go karts. The basic piston valve Yahama, TKM or Comet engines. My engine builder would match the engine blueprint (mod) to the type of racing that it would be doing. Along that lines we would adjust the pipe to match. We would then adjust the header (length and shape) to the weather and altitude (ie barametric pressure, tempurature and humidity). I know we are not that exact in RC racing yet, but we are heading that way.
educated trial and error can still be the best method.
Not to state the obvious, large open track-rpm motor and pipe; tight twisty-bottom end motor and pipe.
However, realize I suck at RC racing. (but I love it!)
Losi XXX-CR
LRP Sphere Brushless
HB D8
Trinity .21
Airtronics
RickBac is offline   Reply With Quote
Old 01-05-2009, 06:53 AM   #23
Zerodefect's Avatar
What about the Axe Rossi 2050? Deos the # mean its a similar pipe?
Zerodefect is offline   Reply With Quote
Old 01-05-2009, 08:53 AM   #24
I agree the Losi RE11 is a 2050 clone. but does anyone know anything about the Losi RE 10
Gary Wiant
Vinyl Graphics Unlimited
Team Losi
Bradley's Fine Line Design
GMK Supply
Signguy Gary is offline   Reply With Quote
Old 01-11-2009, 02:24 PM   #25
bump... anyone know anything about the RE-10?
Gary Wiant
Team Losi
GMK Supply
Old 01-11-2009, 06:18 PM   #26
tex1's Avatar
Red face Not real sure yet.
The RE-10 looks like it is more akin to the JP-1 tourque pipe but it acts different. I'm thinking 3 chamber maybe?? Don't know for sure. It does moake alot of bottom and uses up the fuel.
TEX
Old 01-12-2009, 03:50 PM   #27
Thanks Tex, that is what we found more bottom end good ful economy, but I wasn't sure if it was simillar to any other pipes, it seems better then the JP1, but simillar
Gary Wiant
Team Losi
GMK Supply
Old 01-18-2009, 08:19 PM   #28
bustedpiecesrc's Avatar
Trader Rating: 51 (100%+)
Send a message via Yahoo to bustedpiecesrc
Thanks guys, ive read everything on this site up to here and thats info i would have never been able to get. im tryin to find the best pipe for my RB WS7, and havent been able to figure out which pipe to get i was lookin at the jp2 but looking at the p3 also, which should i get by your experiences? Thanks
EVERYTHING IS FOR SALE
Associated FT NTC3 with Picco/ dirt oval Latemodel
Associated FT TC4 Latemodel MMP fantom 10.5
Mugen MBX6 nova +4
bustedpiecesrc is offline   Reply With Quote
Old 01-18-2009, 08:23 PM   #29
I'm no expert but I've always been told RB's run best with RB Pipes, but when I ran a S5 I always ran a 2050
Gary Wiant
Team Losi
GMK Supply
Old 01-18-2009, 11:08 PM   #30
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
For bottom with good top, try the RB 2020 pipeset.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
