P3 Plugs in my GRP Tuned .21 Buggy Engine
Can I use P3 plugs in my GRP, Tuned .21 Buggy Engines. Specs are:
GRP Engine, Tuned .21 Buggy At a Glance GRP’s engine line is manufactured and designed in Italy using the most up-to-date and advanced mechanical simulation software. The Mario Rossi Tuned 1/8 .21 Buggy engines represent the maximum expression of the industry’s motoring technology. They provide excellent performance at the highest competitive level. Features * Tuned under the technological supervision of GRP’s Mario Rossi * Highest level of GRP engines * Used in competition by Losi's Yannick Aigoin, Adam Drake and Mike Truhe, as well as other top racers * True ABC construction * Comes in a single GRP plastic box Product Specifications Type:Off-Road Buggy Displacement:.21 cu in Bore:16.27mm Stroke:16.79mm Engine (Only) Weight:355 g RPM Range:43,000 rpm Fuel:Nitromethane Cylinder Type:ABC # of Ports:5 |
From what I was told you had to use GRP plugs something about the taper being different. Was told by the hobby store one of the reason why I buy one
Would suggest you keep to the GRPno6 plug. runs best with them.
If your going to stick with GRP plugs run a #4 plug. But YOU CAN use a OS P3 or P4 plug with zero issues.
I would stick with the GRP plugs if you could. But if you had to use a OS plug it will work like previously mentioned. It's best that if you do use an OS to keep using OS plugs and not switch to another brand because the taper is a tad bit different between those turbo plugs. I have seen head buttons that deformed a tad and wouldn't seal to either after someone kept switching brands a bunch at the track.
you can also use odonells plugs ....if you use o.s. plugs you had better get a bunch of them as your head will leak fuel around the glow plug if you switch to other plugs ...
Originally Posted by MattP
(Post 5234449)
X2. :nod: |
Yes, you can use the OS plug in your GRP. Personally, I think the GRP6 plug is way too cold. If your going to use the GRP plug, use the GRP4. This should cure any flame out issues you may have encountered.
If you opt for the OS plug, the P4 or P3 seem to work the best. In the GRP thread there was someone that mic'd out the two brands and found that the very tip of the OS plug was a tiny bit different in the taperor length, but not enough to make any difference in the seal. I switched to the OS plug, based on availability, and price. In a pinch, I was forced to go back to a GRP plug one day, and didnt have any issue with leaking. I went back to the OS plug, and still no issue. This is just my personal experience with the two brand plugs. 8+ gallons later my GRP is a little tired, and needs a rebuild. I will continue to run the OS plug when it is revived. |
sorry if this may be out of topic abit.
i've got the Ninja MR28 (basically a GRP engine..:)) which O'Donnell plug would be suitable the 28? 77 or 99? (i'm using the 77 with my V-Spec and i'm loving it!) or can i use the OS plugs? i've got a P6 lying around, or shld i try a hotter plug? thanks in advance! |
Originally Posted by n.e.r.d
(Post 5236044)
i've got the Ninja MR28 (basically a GRP engine..:)) which O'Donnell plug would be suitable the 28? 77 or 99? (i'm using the 77 with my V-Spec and i'm loving it!) or can i use the OS plugs? i've got a P6 lying around, or shld i try a hotter plug? thanks in advance! ive seen some that leak and some that dont...its hit or miss imo....i would personally stick with the Grp plugs. :nod: |
