Old 12-31-2008, 06:19 AM   #1
Default xt8 truggy users
Hi guys i recently serviced my car and took the throttle servo linkage apart with the engine.
when i put the parts together it seems my throttle linkage seems to hit the centre diff plate
just getting consensus / advice.
1.do u guys put the linkage on top of the servo horn or below?
2. if on top , at what position is the bevel on the carburetor set at? ( as mine is set at about 1 o'clock) with the throttle linkage set above the horn.
thanking you all in advance and a happy 2009
muaythai is offline   Reply With Quote
Old 12-31-2008, 06:30 AM   #2
c baron's Avatar
I have my carb at about 4 oclock and mounted under the servo arm out side hole with the slider on the inside
USED TO BE HURRICANE RC TRACK DIRECTOR
-RC AMERICA-
-XRAY-
-ELITE PERFORMANCE-
-JCONCEPTS-
c baron is offline   Reply With Quote
Old 12-31-2008, 06:51 AM   #3
Default xt tuggy
thanks baron, i am sure u are right and mine was just like yours until i serviced and i think pushed the engine just a bit too forward.
i set my meshing just right. so now unfortunately will have to set my carb at 2 pm and the linkage on the top.
do u use a quick engine mount?
Old 12-31-2008, 07:39 AM   #4
c baron's Avatar
no stock mount. my truck is 100% stock they only thing I plan on changing is the 5mm hubs
-RC AMERICA-
-XRAY-
-ELITE PERFORMANCE-
-JCONCEPTS-
Looking for Truggy - Which is best? sidewayz Singapore R/C Racers 62 06-17-2007 09:33 PM
