Old 12-31-2008, 08:15 AM   #16
mechanic77's Avatar
Default gears
+1 on the hot bodies gears. I use them in my jammin and they are hardened steel and last forever. Also, if you want to convert your X1 CRT to truggy gearing, the hot bodies lightning stadium diffs and pinions will bolt right into the jammin. You also have to change the center diff gear to the hot bodies 50t and the hot bodies entire center diff will fit. If you have any questions on what it takes to convert it over to the truggy gearing, pm me and I will make a list of part #s and send them to you.
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 12-31-2008, 08:22 AM   #17
Triton3d's Avatar
Trader Rating: 17 (100%+)
Originally Posted by rcg33k View Post
No.
ok, are they any hardend steal gears for the Losi 1.0??
Mike
Triton3d is offline   Reply With Quote
Old 12-31-2008, 09:15 AM   #18
JAMMINKRAZY's Avatar
Mike
The stock losi gears are hardened. I think they are aluminum but they are hardened and very strong/durable.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 12-31-2008, 09:57 AM   #19
The XRAY 808 gears are the nicest ones ive seen. They are the same size as Kyosho and OFNA/Jammin gears.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 12-31-2008, 04:55 PM   #20
ok cool.so if the kyosho ones drop straight in then what would i have to do to get the hotbodies ones to fit? i would've thaught that the outdrive shafts would be a different diameter, therefore making the gears different. i will check with my lhs just to make sure. thanks for all you guys help.
hong nor X2 truggy / novarossi / a trasmitter
koenig is offline   Reply With Quote
Old 12-31-2008, 11:48 PM   #21
The Hotbodies gears probably are the same size, but im not 100%. There seems to be a standard size for gears and outdrives for 1/8 scale that only a handfull of manufactuers stray away from.
Old 01-01-2009, 12:43 AM   #22
sickboy's Avatar
Trader Rating: 72 (100%+)
Kyosho's drop right in. Make sure to use the same shim spacing. Jammin spider gears= $16.00, Kyosho spider gears= $5.00.
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 01-01-2009, 01:56 AM   #23
cool, i will probably get the kyosho ones first then. after about 5 or 6 months,im thinking about upgrading them so that they will last alot longer.thats a huge difference in price, any ideas why?
Old 01-01-2009, 07:41 AM   #24
asw7576's Avatar
Originally Posted by jamminnay View Post
i have never heard of them wearing quickly.. i ran the the whole season on the same set in my cr. i do not know of any other companies that make them
Yes, I'm still using the same gears ( 2 years old ).
The secret : shimming on both planetary gears, so they are very close but they don't bind + tamiya ceramic grease.
Old 01-01-2009, 08:56 AM   #25
I'm pretty sure the kyosho ones aren't hardened. If that is the case they will probably be the same as the jammin ones. Unless there is a huge quality difference in the metals used they would probably wear the same as jammin ones. I would get the hb ones.
HB gears
http://www.amainhobbies.com/product_...oducts_id/6820
Kyosho gears
http://www.amainhobbies.com/product_...oducts_id/3892
Here you can see that the K gears are not hardened
for the dollar I would get the hardened ones lol
-Koby Kubrin-
Team Associated B44. Race, Tune and Modify Shadows Electric Off-Road 6171 08-09-2015 07:32 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
diffrential Gump0220 Rookie Zone 9 09-25-2001 09:57 PM
