Old 12-29-2008, 09:13 PM   #1
Default Cleaning engine internals?
Is there any benefit to completely breaking down an engine and cleaning the fuel residue from your engine internals every so often? And if so whats the best stuff to clean em with?
8ight pro Kit, MassiveMods stage 5 modified MRT GRP .21
Jonro is offline   Reply With Quote
Old 12-29-2008, 10:30 PM   #2
Trader Rating: 18 (100%+)
Default YES!!!!!
YES I CLEAN MINE ABOUT EVERY 2-3 GALLONS ITS MOSTLY TO INSPECT EVERYTHING AND MAKE SURE THERE IS NO ISSUES. ILL CLEAN THE INSIDE WITH FUEL I ALSO USE SUPER FINE WOOL AND CLEAN THE TOP OF THE PISTON AND HEAD BUTTON TO GET OFF BURNT FUEL RESIDUE. AFTER ALL DONE ILL SRAY THE INSIDE WITH 1 SPRAY OF MARVEL MYSTERY OIL JUST TO LUBE THE INTERNALS. I FIND THNAT WHEN THEYRE CLEAN THEY JUST RUN ALOT MORE CRISP. THINK ABOUT IT WE CLEAN OUR REAL CAR'S FUEL SYSTEMS RIGHT??
TLR 8ight 3.0, ''Houstonized'' P5XLT
TLR 8ight-E 3.0, Tekin RX8 gen2, T8 gen2 1900
Savox Servos
AKA Tires
Byron's Fuel
donbeatya is offline   Reply With Quote
Old 12-29-2008, 11:07 PM   #3
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
what he said except
you dont need to be in all CAPS it seems like your yelling
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 12-29-2008, 11:26 PM   #4
r1harper's Avatar
Trader Rating: 24 (100%+)
i have started checking more things with digital calibers to check wear and things like that. especially crank pin and rod bushing. mainly for my reference
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 12-29-2008, 11:30 PM   #5
Default sorry
ya sorry about the caps.
Savox Servos
AKA Tires
Byron's Fuel
Old 12-29-2008, 11:32 PM   #6
bigsquidracer's Avatar
i would go with both of the ones up top...
What goes around comes around
bigsquidracer is offline   Reply With Quote
Old 12-29-2008, 11:33 PM   #7
Originally Posted by pinky2252s View Post
what he said except
Probably just didn't realize he had his caps on, Ive done it before.
What else besides expensive nitro can i use to clean them with? full scale car petrol?
Old 12-29-2008, 11:36 PM   #8
Default ...
if you have all of the o-rings out you can also use denatured alchohol
Savox Servos
AKA Tires
Byron's Fuel
Old 12-29-2008, 11:56 PM   #9
aussies1129's Avatar
Trader Rating: 74 (100%+)
its always a good idea to use your rc fuel and a toothbrush in a small container, your rc fuel has lubrication wheres as petrol has nothing and will damage any rubber. remember to fully lube everything especially your bearings,piston,sleeve etc with after run oil when you have it all clean.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 12-30-2008, 03:58 AM   #10
I've had pretty good luck using WD-40 as after-run oil. It will also clean and displace moisture. They start like a new one every time. I use the Traxxas method of after-run treatment. The thinner oil seems to get into more places of the engine.
JLinney is offline   Reply With Quote
Old 12-30-2008, 05:17 AM   #11
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i clean mine every few gallons.. i will cleaner it more frequently if i think someting is not right
jamminnay is offline   Reply With Quote
Old 12-30-2008, 05:50 AM   #12
chunk t's Avatar
When I clean an engine (and I do this to new engines as well) I wash all metalic parts in a mild degreaser, rinse off with water to get all of the degreaser out of blind holes and followup with denatured alcohol to dry up the water. I personally use a mixture of light oil & STP engine treatment to coat the parts prior to assembly.
as to tear down of a working engine... I start with a pressure test to check the bearing's seal; after that I'll pull the plug and the header so I can see the piston face. But I never lift the head (my personal belief). An engine that is burning the correct fuel mixture will have a discolored but clean pistion face. If it looks dirty or gunky (hopefully not that bad) when you sneek a peek, you need to work on your needle settings. With time, once the needles are correct, the crap will burn off to a clean surface. I will pull the back plate and front plate (if the engine is designed in that manor) inspect the bearings and rod. I only replace damaged rods, if the rod is WORN to the point of needing replacement, the P&S are probably beyond a pinch and should be replaced as well.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 12-30-2008, 07:38 AM   #13
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Depending on your fuel, a good mixture will leave a small brown coating on the internals. Over time, this will turn to a black carbon like coating. It will go down the side of the piston and progressively thin out. This is fine. Over a long time, the carbon can get thick, but if the engine runs fine, you can leave it alone. Never clean the side of the piston or the inner sleeve where the piston runs, only the piston top and head button if you want to remove excessive carbon build-up.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 06:15 PM
Engine decides to lock up on me. Help! sokar Nitro Off-Road 30 08-15-2009 09:56 AM
Race Fuels??? Gearhead racer Nitro Off-Road 112 06-21-2009 06:39 PM
OS TZ .12 HELLOkitty Nitro On-Road 151 06-03-2006 04:51 AM
Best way to clean my savage onintks Monster Trucks 10 03-01-2006 06:35 AM
which engine to get? Devil666 Malaysian R/C Racers 52 12-17-2003 05:21 PM
