Old 01-02-2009, 09:00 PM   #46
is it safe or ok to use a steel wash from home depot to put behind the collet so my flywheel doesn't hit my carb output?
xpertpredator is offline   Reply With Quote
Old 01-03-2009, 07:27 AM   #47
Integra's Avatar
Go to your LHS and get a proper shim.
Old 01-04-2009, 03:51 PM   #48
man go with a radical 621t if you run buggy if you run truggy go with radical 628t. these motors are crazy on bottom and top will out run v-spec and nova
and last easy 10 gallon if not more. They are hand made in a small factory in italy quality is top notch. they are borderline modden straight out the factory. u can pick up @ gotnitroonline .com ask for dave he will give u a good deal. trust me u want these BADBOYS!!!!!!!!!
mugen boi is offline   Reply With Quote
Old 02-13-2009, 11:07 PM   #49
lethalleigh29's Avatar
quick question how many shims do you have to add from the factory to run 25-30% nitro i have added 1 not sure if that is enough. what are these motors designed to run on from the factory.
lethalleigh29 is offline   Reply With Quote
Old 02-14-2009, 10:14 AM   #50
sugs's Avatar
They come from the factory shimmed for 30%.
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 02-14-2009, 01:56 PM   #51
OK,
I'm running a modified version of the B7 pro and its insane coupled to the 2013pipe in my RC8T and i keep popping plugs I'm running a P3 and I'm killing them in 1 tank of juice Ive just brought some o'donnell 77T hot plugs maybe I'm using the wrong plugs.
What plugs do you all use in these motors.
Old 03-16-2009, 08:05 PM   #52
does anyone,still run these motors or have you switched to the new version
Old 03-16-2009, 09:09 PM   #53
sugs's Avatar
I checked the Werks thread on the grid and they recommend the O'Donnell 97T or RB6T. So looks like medium to cold plugs is what you should be running. I'm guessing since your B7 is modded, that would probably dictate some what plug you would use. I run the standard head button so the plugs aren't the same, but I know my motor seems to like the colder plugs.
Old 03-16-2009, 09:45 PM   #54
Sweet mate i have since palmed off the modified motor an no doubt the person will have better luck than me.
I still have a brand new b7 pro that i intend to put in my Rc8t
i will be using odonnell 97t plugs hopefully with great success.
Old 04-14-2009, 09:00 AM   #55
RyyRyy's Avatar
Trader Rating: 16 (94%+)
Lookin for some new engines to start running...
I've ran O.S. (VZB Vspec) for 2 years, Novarossi P5/421b for 3 years...Love em but ready to try somethin new...
How do the werks engines compare?
What Pipe and plug for the B7?
Thanks!
RyyRyy is offline   Reply With Quote
Old 04-14-2009, 10:14 AM   #56
omarwashington's Avatar
Im currently using the JP-3 pipe for this mill, Iím getting about 7 to 8 minutes a tank(8+ minutes if Iím driving smooth). I would like to try one of the Dynamite pipes on this to increase fuel minutes but as of right now Iím on a really tight budget.
I was using the OíDonnell med plug but it wasnít getting hot enough so I went with the O.S. p3 which is better. It gives it a little extra power also.
RCCARS!
omarwashington is offline   Reply With Quote
Old 04-14-2009, 10:51 AM   #57
RyyRyy's Avatar
Thanks!!
I've just heard alot of mixed opinions on the b7's and just want to know if i should stay with O.S. or try these out this year...
Old 04-14-2009, 07:13 PM   #58
RyyRyy's Avatar
any opinions??
Old 04-14-2009, 11:46 PM   #59
Krawl's Avatar
I own both B7 and vspec, IMO Werks TL21 B7 PROC is fast on mid and high end, but it's very weather sensitive engine, hard to tune, weak cooling fins and weak crankshaft! (broke mine and now that engine is lying on my bench waiting for crankshaft that cost $200)...Then v-spec...what can I say...nothing but satisfaction....it's 3 ports engine but wickedly fast! On straight line drag test could easily catch up the mighty RB WS7III. Very easy to tune and hold it well in every weather conditions....you need 2050 pipe for small to medium sized track or 2060 for large track....mine combined with werks 2013 pipe, it works very well...
HPI Blitz EZRUN 60A + 6000kv + 2S + 4000mAh 25C
Jammin SCRT10 XERUN 120A + SP Silver Arrow V10 3.5R + 2S + 5800mAh 25C
Krawl is offline   Reply With Quote
Old 04-14-2009, 11:49 PM   #60
Originally Posted by Krawl View Post
I own both B7 and vspec, IMO Werks TL21 B7 PROC is fast on mid and high end, but it's very weather sensitive engine, hard to tune, weak cooling fins and weak crankshaft! (broke mine and now that engine is lying on my bench waiting for crankshaft that cost $200)...Then v-spec...what can I say...nothing but satisfaction....it's 3 ports engine but wickedly fast! On straight line drag test could easily catch up the mighty RB WS7III. Very easy to tune and hold it well in every weather conditions....you need 2050 pipe for small to medium sized track or 2060 for large track....mine combined with werks 2130 pipe, it works very well...
Which year was the B7?
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Werks engines?? anybody run them?? KThatcher Nitro Off-Road 46 02-15-2009 05:29 PM
Glow Plug Recommendations cheesewhip Nitro Off-Road 11 09-05-2008 12:41 AM
WERKS B7 PRO TL MOTOR LESS THAN GALLON KEITH R/C Items: For Sale/Trade 7 10-27-2007 07:35 PM
