Old 12-29-2008, 03:13 PM   #1
vladconnery's Avatar
Trader Rating: 35 (100%+)
Default Werks racing clutch
I got this clutch in a trade on a new engine. I have no idea about this clutch it worked fine. I read that it is adjustable and uses different compound shoes roulon and ceramic as well as carbon. What are your thoughts, experiences and suggestions.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 12-29-2008, 03:18 PM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
they are alright clutches... good luck getting them set right from my experience. i sold mine after just a couple of tanks, 3 shoe setups are fool proof
jamminnay is offline   Reply With Quote
Old 12-29-2008, 03:27 PM   #3
r1harper's Avatar
Trader Rating: 24 (100%+)
3 shoe is da way to go
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 12-29-2008, 04:58 PM   #4
Integra's Avatar
4 Shoe is significantly better then a 3 shoe imo...as for spring wear and general clutch life.
Ive also played with the Werks and had the same issue of the adjustment nut wanting to walk...no matter what loc tite i used or how long i let it sit...it would ALWAYS let loose and lock up.
Old 12-29-2008, 06:58 PM   #5
Trader Rating: 19 (100%+)
I love the werks clutch, go with the sarbon shoes or 2 carbon and 2 rulon, it is a bitch to get set right but once you get it right you will never want another 1.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 12-29-2008, 07:07 PM   #6
jamminnay's Avatar
well that may be correct but some of us do not wanna keep trying to get it adjusted! no really i hated mine. people must like them though otherwise they would not be on the market
Old 12-29-2008, 07:55 PM   #7
I love mine & had no problems setting it up,easy change mounts help there. When I found the shoes(2 carbon 2 teflon) & spring setting(1.5mm of thread showing) & spring(soft) I simply ground down my clutch nut to be flush with the adjusting nut then its the same every time for all my werks clutches. RED loctite the adjusting nut & heat of motor & clutch will keep it from staying solid. The instructions can be found on the werks site & tell you what the most common settings are. Give it a try before you toss it, it wont cost you anything & clutch bells & bearings will last forever. When the purple ano that touches the shoes wears off completly & flywheel material just starts to divot its time for a new clutch set complete. Should cost about $60 for 10 gal worth of trouble free use if you lube bearings after every race day & you should get 3-5 gal per set of bearings lubing like that or 1 gal of no maint.You dont like it,send it to me.
butch man is offline   Reply With Quote
Old 12-30-2008, 01:21 PM   #8
Well I'm going to say this about the clutch. "Damn it's smooth!!" I ran approximately 6 tanks through my 8T today even at low speeds it just did what it was supposed to do. I actually didn't need to spool up to get it to engage. It was almost like driving a car. If I gunned it tires spun slinging dirt everywhere. If i gave it just a little throttle it rolled like I was trying to park. I was impressed actually. Now how this will translate on a track I could not tell you. My initial thoughts are its a nice clutch. Its still set the way I got it haven't tried to adjust it yet not even sure if I need to. I have 4 carbon shoes and its on a Trinity Platinum A. Drake edition engine. I not even sure what I was more impressed with the engine or the clutch. First time using a Picco based engine.
KO PROPO EURUS
Old 12-30-2008, 02:10 PM   #9
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
This was exactly what I thought about the Werks clutch as well. The general opinion on performance on most forums and in the pits seems to be 50/50. A fellow racer was running the same clutch and his blew up during a qualifier. I've been running the same set of shoes for two seasons and I am constantly worried about the adjustment nut coming loose since I fiddled with it, but it hasn't walked on me yet.
K_B is offline   Reply With Quote
Old 12-30-2008, 02:12 PM   #10
RickBac's Avatar
Trader Rating: 20 (100%+)
I had one and loved it. It does wear shoes quickly compared to aluminum 3 or 4 shoes but once it is set right it is great.
Losi XXX-CR
LRP Sphere Brushless
HB D8
Trinity .21
Airtronics
RickBac is offline   Reply With Quote
Old 12-30-2008, 02:13 PM   #11
wb-racer-ace's Avatar
Trader Rating: 28 (100%+)
Send a message via Yahoo to wb-racer-ace
I loved the one I had on my mugen, once I got it set it was perfect all season. thinking about going back to it on my 8ight
ADVANCED CUSTOM ENGINEERING.....custom components designed for racers, by racers!!!!! email acercparts@yahoo.com for info
http://photobucket.com/acercparts
email [email]acercparts@yahoo.com[/email] for info
[URL=http://s811.photobucket.com/albums/zz37/acercparts/]ACE Products Click Here[/URL]
wb-racer-ace is offline   Reply With Quote
Old 12-30-2008, 02:22 PM   #12
I actually want to try some of the other shoe combos that were mentioned. I'm just afraid to take it apart now. Heck if it ain't broke don't try to fix it.
KO PROPO EURUS
Old 12-30-2008, 06:36 PM   #13
8&stuff's Avatar
Trader Rating: 55 (100%+)
I got several werks cutches a while back with rulon and composite shoes..I spent tons of time setting one up in my buggy and truggy. I couldnt with either of the springs get one set up with any options whatsoever in buggy. now in my 8t with composite shoes and the green spring(mind you these were all new,never used)and the ctutch nut tightened until it was not possible to tighten anymore, left it there and ran just short of 1 gallon that way..it was smooth. I decided to go back to the losi clutch cause i could get more $ out of it and i had tons of new losi clutch parts. brand new unscratched they seemed to sell ok on ebay..
Mark Buecker
8&stuff is offline   Reply With Quote
Old 12-30-2008, 06:38 PM   #14
8&stuff's Avatar
a yeah sry forgot to say the werks clutch is a rip off and even bigger pain in the arse..
Mark Buecker
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9300 03-27-2017 05:54 PM
VTX B1 RTR 1/8 Buggie owners? rltanner Nitro Off-Road 66 04-30-2013 07:12 PM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
werks clutch HELP!!!! mamba4life Nitro Off-Road 37 05-01-2009 07:20 PM
Racing Truggy For Sale! Track is closing and it's time to retire truggy Wolverini R/C Items: For Sale/Trade 19 07-07-2008 08:04 PM
F/S Werks Racing Adj. 4 shoe clutch NEMESIS44 R/C Items: For Sale/Trade 8 06-13-2008 10:16 AM
Werks 4-Shoe Power Clutch (NIP) SeattleRCer R/C Items: For Sale/Trade 9 10-25-2005 05:18 PM
