Old 12-27-2008, 01:39 PM   #1
r1harper's Avatar
Trader Rating: 24 (100%+)
Default Fuel tank leak..can you fix?
i got a small leak form my tank Xray 808. i can tank the tank off and plug one end and blow like a mofo on the other and i cannot get a leak to expose itself. as soon as i put it back on da car in a bout a minute i start to see the air bubbles....any ideas? i have had this prob before and was never able to fix it
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 12-27-2008, 01:45 PM   #2
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
I would replace the tank or you could be chasing it for a while...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 12-27-2008, 01:47 PM   #3
r1harper's Avatar
well that normally the case but tanks get expensive....i am definatley gong to get a couple, but would like to try and repair.
JESUS SAVES, WESLEY
Old 12-27-2008, 01:57 PM   #4
Trader Rating: 21 (100%+)
I've had good luck fixing leaks with shoe goo, but you've gotta be able to pinpoint where its coming from.
Try immersing it in a sink full of water. Def look at lid and seal, they cause a lot of the leaks. You could just shoe goo the seams - that's where the leaks I've fixed have been if they were not the lid or seal.
Duster_360 is offline   Reply With Quote
Old 12-27-2008, 01:59 PM   #5
Trader Rating: 66 (99%+)
new tank, without a doubt
pwnzor is offline   Reply With Quote
Old 12-27-2008, 02:18 PM   #6
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
R1harper.. are you sure the leak is from your tank? I would check your fuel filter..if you use one...
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 12-27-2008, 02:35 PM   #7
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i would def replace.. i have heard of guys using a soldering iron to fix a leak that is in the seam and that is it.. i would just replace it and be safe!
jamminnay is offline   Reply With Quote
Old 12-27-2008, 02:38 PM   #8
r1harper's Avatar
no filter...just line and the engine is not leaking either. it started the tale tale signs of a leaking tank so i shut it down. i put it under water and no bubbles, then i put a small line on it and gently put pressure on it with an air com. and with just a little air if i keep the pressure on it the lid will open but i cannot open it by mouth...so i will just get a new one. unless someone knows a way to fix it.
JESUS SAVES, WESLEY
Old 12-27-2008, 09:14 PM   #9
LVBaja's Avatar
I had numerous issues with my Losi 8ight tanks for a while. I went through 6 of them in a matter of a couple months. I tried several different methods of sealing them, but nothing seemed to work. I finally sent them back to Horizon Hobbies and they sent me new tanks. Figures that now that I have 5 spare tanks, I haven't had a leak in over 6 months!
LVBaja is offline   Reply With Quote
Old 12-27-2008, 09:30 PM   #10
imaxx21's Avatar
Send a message via AIM to imaxx21
Wesley, i got some tanks you can have..
email me picou316@gmail.com
imaxx21 is offline   Reply With Quote
Old 12-27-2008, 10:06 PM   #11
r1harper's Avatar
crash i hit you back..thanks
JESUS SAVES, WESLEY
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Input on Exceed-RC Xtreme buggy engine? FrankW Nitro Off-Road 17 09-11-2011 05:32 AM
Trinity EXTECH .21 Fierle03 Offroad Nitro Engine Forum 2130 06-09-2011 07:01 AM
RDLogics Mongoose KMac Nitro On-Road 2117 03-09-2011 12:57 AM
