Old 12-26-2008, 11:38 AM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default .21 engine question
If you front bearing is a little wet - and you can tell that the wetness is coming from oil on the inside - does that mean the bearing needs to be replaced?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 12-26-2008, 11:39 AM   #2
free2day77's Avatar
usually, thats what that means.. how many gallons does the engine have on it?
Sponsors:
Hotbodies
Trinity
Answer RC USA
Fastlane Graphix
free2day77 is offline   Reply With Quote
Old 12-26-2008, 11:46 AM   #3
wstuart's Avatar
its an os vspec with only 3 tanks on it.
The thing is I just replaced the bearing and havnt even put the clutch back on.
Im wondering if the bearing is just bad
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 12-26-2008, 11:47 AM   #4
free2day77's Avatar
it could be.. not sure. I wouldn't think that after only 3 tanks it would be leaking.... I had an RB front bearing go bad before the 1 gallon mark... but not 3 tanks
Sponsors:
Hotbodies
Trinity
Answer RC USA
Fastlane Graphix
Old 12-26-2008, 11:56 AM   #5
Trader Rating: 1 (60%+)
no it does not mean you need to replace it. it means the engine is running very rich and u need that for atlest 1/2 gallon of fuel and it will go away. been in the hobby for a long time. any more ? u can pm me or call me thanks nate
dx3r pro
mbx6 with nitrotech engine
soon mbx6e
mungen is offline   Reply With Quote
Old 12-26-2008, 11:56 AM   #6
mugenb46's Avatar
it's not uncommon to see the OS leak fuel from the front, they are so fat during breakin this is when it seems to happen the most, i would continiue to run it in, unless you think the front bearing you replaced may not be seated all the way. when you start to lean the motor out the leak 8 times out of 10 goes away and last for several gallons, this is what i have seen out of alot of v specs, good luck
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 12-26-2008, 12:11 PM   #7
captain america's Avatar
+1
The front bearing on my Nova weeps a bit too and it's normal, especially if you run it rich. If you want to be safe, remove the bearing from the case, clean it, re-lube it and see if it feels gritty or notchy. If it still turns smoothly, just put 'er back in. If not, replace.
captain america is offline   Reply With Quote
Old 12-26-2008, 12:16 PM   #8
wstuart's Avatar
Oh thats good news - If youve seen my other post youll know that Ive had a rough morning with my vspecs.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 12-26-2008, 12:21 PM   #9
chunk t's Avatar
Stuart,
I'd do a pressure check on the bearing.
To do a simple blow check, the back plate & plug must be installed and the carb removed. Turn the crank so the induction port is open and blow forcefully into the carb opening. Look, listen & feel for any signs of pressure loss. A leaky bearing will be pretty evident.
A little oil loss though a bearing isn't bad, you know it's getting a good lubing .
chunk
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 12-26-2008, 05:12 PM   #10
Trader Rating: 42 (100%+)
+1.... I have seen two or three of these leak for a bit, then quit. Both of my speeds leaked some when new and I saw another guy's do it. Run it a little more and monitor it.
mracer is offline   Reply With Quote
Old 12-26-2008, 05:22 PM   #11
Trader Rating: 8 (90%+)
I had a rb c6 bbt leak during break in and for the first 1/2 gallon or so. I contacted rb and they said it impossible to seal the front bearing totaly. as i race tuned it for max power the leak went away for the most part.
franklucas is offline   Reply With Quote
Old 12-26-2008, 05:34 PM   #12
easyryder's Avatar
Dont worry about it If the engine is running well and leaks a bit, It is doing well, mabye your pit man spashed too much, wait till next run, dont be too anal, dont waste money, keep racing that sucka!!!
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
Picco P9 EVO3 .21 Race Engine nigelnuggets Onroad Nitro Engine Zone 130 03-11-2015 08:02 AM
Trinity EXTECH .21 Fierle03 Offroad Nitro Engine Forum 2130 06-09-2011 07:01 AM
AREA52 RC RANCH RACEWAY Leopard1 Northwest Racers 5272 01-01-2011 01:09 PM
Low end engine pinky2252s Nitro Off-Road 28 04-16-2009 04:29 PM
A quick Novarossi Plus21 question air8 Nitro Off-Road 44 08-30-2008 02:18 AM
