Old 12-26-2008, 11:37 AM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default .21 ENGINE PROBLEM?!?!
I seem to have stripped the hole for the bolts that hold down my cooling head.
Is there a fix for this or do I have to buy a new crank case?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 12-26-2008, 11:42 AM   #2
jpz_67's Avatar
Trader Rating: 56 (100%+)
Dude that sucks. Not sure if there is a heli coil repair kit the small or not but you may be better off just buying a good, used case. What motor as I have a bunch of parts motors. I may be able to help.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 12-26-2008, 11:44 AM   #3
wstuart's Avatar
its an os vspec
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 12-26-2008, 11:59 AM   #4
jpz_67's Avatar
You may be in luck, let me dig through my stuff and I will let you know what I have. You have to be careful on those os based motors. They have very specific screw size of 2.6 mm, a 2.5 mm screw which is readily available will feel as if it fits but when you crank down.... Not saying this is what happened but I have seen it happen a lot here locally.
Old 12-26-2008, 12:12 PM   #5
wstuart's Avatar
hmm yeah after I tried the os screw I used a pico screw and I think that was the nail in the coffin for the holes
I actually know ecatlly what did it. I was using an odonnell head which required that I cut the screw short. I think it was either a bad cut on the end of the screw or the fact that I was using a ball tip allen to screw them in (always use a straight tip!). It screwed in at angle and tore it up
Im the kinda guy that has to learn by making the mistake
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 12-26-2008, 01:10 PM   #6
jpz_67's Avatar
I have an extra case, pm me if interested.
Old 12-26-2008, 02:37 PM   #7
jpz_67's Avatar
Heres the pics.
