Old 12-26-2008, 04:02 AM   #1
Unhappy help with my kyosho inferno mp 7.5 mk3
hi i just got my kyosho inferno sport 3 for christmas and im doing the break in but when i start the engine it revs at full throttle and i have turned the idle speed screw but still no luck
someone please help
thanks
hypergpx4 is offline   Reply With Quote
Old 12-26-2008, 04:12 AM   #2
aussies1129's Avatar
Trader Rating: 74 (100%+)
HI it might be a good idea to do a search on engine tuning and possibly engine setup, but to get you out of trouble try this,
turn on your transmitter then your buggy, take off your engine filter and look down the round opening and see how far open the carb is, follow your engine manual and this will tell you the there should only be a slight opening about 1.5mm approx, thats where you set your servo at. start your buggy at this setting and your are in business, if you find its to low a rpm just adjust a little on your transmitter. follow your engine setup manual which should of came with your kyosho buggy.
goodluck!
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 12-26-2008, 04:16 AM   #3
thanks i will try that and get back to you
