Old 12-25-2008, 08:32 PM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default VSPEC building question
putting my vspec back together for the first time - just wondering if I put in the sleeve and then the two shims on top of that. Also sdo I line up the grooves on the sleeve and the crank case - it seems like I do but just wanted to be sure
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 12-25-2008, 08:40 PM   #2
scapbell7's Avatar
Trader Rating: 18 (100%+)
Put your sleeve in with the notch in the sleeve lined up with the pin in the case (Make sure your piston is installed correct with the clearanced side of the skirt of the piston is going to face the backplate). Put the shims on once the sleeve is installed and you are ready to put the button on. Hope that is what you are looking for.
scapbell7 is offline   Reply With Quote
Old 12-25-2008, 08:52 PM   #3
wstuart's Avatar
awesome - yeah that is exactly what I needed to know
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 12-25-2008, 09:44 PM   #4
imaxx21's Avatar
Send a message via AIM to imaxx21
thats not right, the raised side faces the front of the engine...
imaxx21 is offline   Reply With Quote
Old 12-25-2008, 09:45 PM   #5
imaxx21's Avatar
Old 12-25-2008, 09:48 PM   #6
chris c's Avatar
Trader Rating: 60 (100%+)
lol i was just going to post that...hope he gets it before he trys to start it!!!
If you can make it I can break it
chris c is offline   Reply With Quote
Old 12-25-2008, 09:51 PM   #7
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
X2 The long side of the skirt always faces the back of the engine(AKA the raised or clearanced side faces the front of the engine away from the backplate)
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 12-26-2008, 03:46 AM   #8
wstuart's Avatar
nice save guys - got it
thanks for the pic - it helps a ton
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 12-26-2008, 04:32 AM   #9
imaxx21's Avatar
no problem, thats just a shot from the manual
Old 12-26-2008, 06:22 AM   #10
scapbell7's Avatar
Thanks for correcting that. Sorry for the wrong info I actually had it wrong in my motor I just put back together I did run it but I just corrected it and there was no damage that I could see. Sorry again. I just learned a lesson the hard way.
Old 12-26-2008, 07:04 AM   #11
My bad, I will double check next time before posting. Thanks for correcting that.
No big deal man. We all make mistakes.
-Koby Kubrin-
