Old 12-25-2008, 02:25 PM   #1
Default Damn brakes!
Hey all,
Just wondering what some of you do to keep your brakes stopping hard? I have twin discs either side of the centre diff and boy, no matter what I do in terms of set up and cleaning I cannot get the pads to bite. Its really starting to p#ss me off.
HJTRBO is offline   Reply With Quote
Old 12-25-2008, 02:58 PM   #2
Nitroburner9's Avatar
what servo are you using. A weak servo and improper linkage setup will be the two problems your having. What chassis are you running?
Nitroburner9 is offline   Reply With Quote
Old 12-25-2008, 04:50 PM   #3
losi_racer's Avatar
Trader Rating: 25 (100%+)
idk what your problem is, this is just a tip. To give ur pads an extra uph. Sand them with like 250 grit sand paper, works great on mine
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 12-26-2008, 03:08 AM   #4
Cool thanks. Sand paper and brakeclean worked well, but still not the best. I have the linkage set to give the most mechanical advantage. Its a tamiya3004 servo. Chassis is a Nitrage. Any ideas on a replacement servo? Brand, specs etc.
Cheers all
Old 12-26-2008, 03:13 AM   #5
hobbipro's Avatar
Trader Rating: 21 (100%+)
Your servo is too weak, Get something in the 90oz range. Futaba S3305 or similar would be fine. BTW I also believe the servo arm on your Tamiya servo have 25 splines, so a Futaba would brop right in without having to change arms.
hobbipro is offline   Reply With Quote
Old 12-26-2008, 03:23 AM   #6
vladconnery's Avatar
Trader Rating: 35 (100%+)
+1 On your servo being weak I run a 3305 in my losi and it stops on a dime. If I am not mistake a 3305 is about $60 bucks spend the extra $20 and get you a Ace 1015 digital. linkage setup is also a source of throttle brake problems. Even once you get a better servo work on your linkage.
I would not use 250 grit sandpaper more like 1000 grit is best. 25o grit takes of to much per stroke. You want to sand it down the least amount possible to achieve the desired effect. You can always sand it a little more with 1000. You can never put back on what you've taken off.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 12-26-2008, 03:40 AM   #7
[QUOTE=vladconnery;5210971
I would not use 250 grit sandpaper more like 1000 grit is best. 25o grit takes of to much per stroke. You want to sand it down the least amount possible to achieve the desired effect. You can always sand it a little more with 1000. You can never put back on what you've taken off.[/QUOTE]
I hear that! I had some 180 laying around... big mistake. Grabbed the 2nd hand pads I had and bought some 600. Much better! I just bought a cheap and nasty TowerPro 955 off E Bay, cheap enough to throw away if its crap. I'll look more into the Futuba 3305. Not having to make any mods is always good.
Thanks all
NP
Old 12-26-2008, 06:13 AM   #8
BAUSTIN's Avatar
Futaba S3305 HD Standard Servo w/ Metal Gears
SKU: FUTM0045
Economical HD Servo with Metal Gears and Ball Bearings
Our Price: $34.99
anywhere on the net.......
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 12-27-2008, 11:16 PM   #9
Couldn't be bothered waiting for the al cheapo E Bay servo to arrive so I went down and grabbed a Futaba 3010. Magic, I got smoke coming off the pads (after an aggressive tuning session) and she stops on a dime. Very happy, thanks for your help people.
Old 12-29-2008, 03:01 PM   #10
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
yep a better servo will def halp.. just make sure your endpoints are set correctly so you do not fry that new servo
jamminnay is offline   Reply With Quote
Old 12-29-2008, 03:15 PM   #11
+1
KO PROPO EURUS
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Tamiya TB-Evolution III rc-zombies Electric On-Road 7237 11-16-2016 05:09 AM
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
t-plate porkey Electric Off-Road 40 09-08-2008 12:24 PM
Car is steering to the left!!! Ooj Australian Racing 11 02-22-2003 01:34 AM
