Old 12-24-2008, 04:51 PM   #1
desertbird's Avatar
Default ringed?
So I was looking at the flyer Tower sent me and noticed airplane engines that say ringed.
Is this piston rings? If it is why don't car engines have em? I'd imagine they'd last longer with rings...
desertbird is offline   Reply With Quote
Old 12-24-2008, 05:02 PM   #2
bigsquidracer's Avatar
idk. thats a really good question ad rebould would be easier and no more abc engines idk. maybe those are 4 stroke engines??
What goes around comes around
bigsquidracer is offline   Reply With Quote
Old 12-24-2008, 05:11 PM   #3
desertbird's Avatar
they are 2 stroke.
Old 12-24-2008, 05:12 PM   #4
rossoh10's Avatar
the nitro engines we run,run off the compression the sleeve and piston make..........I believe the rings in a 4 stroke make the compression,and there is no piston to sleeve pinch........Even if we did use rings in these engines they probably wouldn`t stay where they were suppost to when the engine is turning at 35,000 rpms......4 stroke engines don`t turn half that number in rpm....
TEAM WTF
RC10B5m
rossoh10 is offline   Reply With Quote
Old 12-24-2008, 05:13 PM   #5
rossoh10's Avatar
TEAM WTF
RC10B5m
Old 12-24-2008, 05:16 PM   #6
rossoh10's Avatar
Can you post a link to the engine your looking at
TEAM WTF
RC10B5m
Old 12-24-2008, 05:16 PM   #7
desertbird's Avatar
I must of mis-read it. That makes sense. Thanks!
Old 12-24-2008, 05:25 PM   #8
Djballen's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXCNA5&P=7
These are airplane four stoke motors.
Djballen is offline   Reply With Quote
Old 12-24-2008, 05:45 PM   #9
rossoh10's Avatar
Desertbird said it was a 2 stoke ringed engine........
post a link desertbird to the eninge your talking about
TEAM WTF
RC10B5m
Old 12-24-2008, 05:48 PM   #10
jaylude22's Avatar
Trader Rating: 93 (99%+)
The nitro engines in helicopters use a ring, they are not 4 stroke. Here's an example: http://www.amainhobbies.com/product_...oducts_id/9471
I agree with rossoh, the ring would not stand up to the rpm that our car engines are operating at. The specs for the engine in the link I attached state it's practical rpm range between 2,000-20,000. We all know that the car engines are operating at considerably higher rpm.
jaylude22 is offline   Reply With Quote
Old 12-24-2008, 06:03 PM   #11
jrwoodchuck's Avatar
I've been flying heli's for 15 years and yes, ringed engines can't hold up to the rpm. We stay around 15,000 rpm the entire flight (loaded and unloaded) and when the ring is warn out, it's $20.00, and you got a new engine. But I will admit, I love hearing 33,000 rpm in my buggys.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 12-25-2008, 05:59 AM   #12
desertbird's Avatar
thanks guys, I knew there had to be reason our engines didn't use em.
Old 12-25-2008, 12:40 PM   #13
gubbs3's Avatar
Yes, the rings won't hold up to the high rpm that our engines turn. This is compounded by the problem of size as well. You will notice if you look around that the smallest ringed engines you'll find are usually .90 and larger. There are a few in the .60 range that are ringed but are usually not the most potent performers. As the piston gets smaller the ring must also be made smaller, and this further reduces its durability.
gubbs3 is offline   Reply With Quote
Old 12-25-2008, 01:33 PM   #14
wingracer's Avatar
Trader Rating: 23 (100%+)
Many airplane motors use rings. Most are four stroke but some two strokes are ringed too.
One of the many problems with rings in car motors are the enormous intake and exhaust ports. Designing ports that big that wouldn't snag the rings (and destroy the motor) would be almost impossible. Ringless is a much better option for our application.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-25-2008, 05:36 PM   #15
Trader Rating: 21 (100%+)
Look at the diff in RPM - plane 15-16,000, car 35,000+ RPM. Piston rings can't handle the rpm - actually its the g loading when the piston direction changes that they can't handle.
Duster_360 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 21154 Today 08:55 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
The Seattle Indoor Raceway PutAwayWet Northwest Racers 2477 02-28-2014 02:00 PM
