Old 12-24-2008, 08:17 AM   #1
Mercury9's Avatar
Default Tuning WS7 lll Advise
Hello everyone I'm new to the forums and I'm posting my very first question.
My question is for those that are running a RB what are your temps, at factory setting 3.5 out on HSN and 5 out on LSN, my temps will go upwards of 260, where are the people saying that there motors are running STRONG at 220 and below? Or maybe i should go 4 turns out on the HSN to start with instead of 3.5, at 3.5 out there is good smoke and the car feels very light got good punch and the Top is scary sick...the car idles like a dream i got about 7 gallons through it new conrod at 3 gallons and has good pinch..Oh and im running an odonnel red(med-hot) glowplug, i do have an Rb #6 plug for a sp are running 30% (50 degree weather Texas for the Lost).If u Run a different Brand motor like OS etc and running hot than others let me know... THX
Mercury9 is offline   Reply With Quote
Old 12-24-2008, 08:30 AM   #2
Steve Walters's Avatar
I have a WS7 III as a practice motor, and it likes to run (With a good tune) around 250-270. I don't tune via temps, but performance, sound & smoke. As long as there a light smoke trail throughout the entire power ban, let the temps fall where they will.
I'm not sure of the needles setting on this motor. But I'm sure a RB fan will know..
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 12-24-2008, 08:45 AM   #3
Mercury9's Avatar
Oh cool, thx for the reply, Hmm I've been steadly trying to richen it up to get the temps down to the 230-240 range, i have not even leaned it out so i guess there is untaped power still, because i have a pretty heavy smoke trail on the Straight away...
______________________________________________
Team Xray 808
RB Concepts WS7 L2g Spektrum Racing Hitech JR Byrons Gen2 Fuels Jammin AKA Tires Ofna
Old 12-24-2008, 09:13 AM   #4
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i run mine at 250-270 and screams like hell with rb6 plug.. around 220 i lose to much power.
jamminnay is offline   Reply With Quote
Old 12-24-2008, 09:36 AM   #5
8&stuff's Avatar
Trader Rating: 55 (100%+)
jp pipes can push temp up on rbs. on my 3 port w/jp3 it runs hot 250-260 and is a fuel hog. with my s5 w/turbo plug fresh, right over 1 gallon w/086&short header mine dont budge over 220 and runs great.
Mark Buecker
8&stuff is offline   Reply With Quote
Old 12-24-2008, 09:36 AM   #6
jamminnay's Avatar
i run the 2045 on mine with a 6.5 restrictor
Old 12-24-2008, 05:38 PM   #7
vladconnery's Avatar
Trader Rating: 35 (100%+)
I have that engine as well as other RB's first. I find RB's like a slightly rich bottom. 2nd I run mine at 230-240 I get great power. 3 RB's do not like JP pipes just say no. Ask Rody himself on the RB USA site. You will notice a definite drop in temps if you change from a JP to say the 2045. As far as needle turns your engine is as different as fingerprints no 2 engines are exactly the same. Tune your engine (needle turns) to best suit the engine and the driver. 3rd I never like 260 its to close to 280 and 300. It only takes a slight changes in the weather, fuel, track conditions, CB or C shoes or engine alingment to make an engine running 260 to start running 280 290.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 12-24-2008, 07:31 PM   #8
chunk t's Avatar
It sounds like you have a good supply of fuel running through the engine. That's good. Though you may be getting high temp readings, if you haven't had to lean the needle to get good power, keep running at your current temp (250-260F). Fuel adds cooling, a lot of fuel adds a lot of cooling. I wouldn't be surprised if the sleeve is actually running 10-deg F below the head temp you're reading. This engine's a keeper, as long as it likes to run on a fat needle, I guarantee you're going to get a lot of hours out of this engine before P/S will need to be replaced.
chunk
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 12-24-2008, 09:43 PM   #9
You may need to check your temp gun. My rb with jp 1 runs around 220 and is very fast.
60*, coldfusion fuel, south ga
Mugen, RB, Cold fusion fuel
hambydsgb is offline   Reply With Quote
Old 12-25-2008, 01:31 AM   #10
+1 .... very fast
Joey Platinum is offline   Reply With Quote
Old 12-25-2008, 07:50 AM   #11
cbaranski's Avatar
Trader Rating: 43 (100%+)
I'm running a my WS7III with the RB 063 pipe and the 198 header and my temps are around 208-215 and this engine love fat needles, at least mine does. I use the RB #6 plug 7mm restrictor, Byron Gen2 30%
Chuck
Chuck Baranski www,pikemotorsportsrc.com
Xfactory SCX60CF w/ 12mm BB, Tekin RSX, Tekin RPM 17.5, Savox 1258
AE B5M FT, Tekin RS, Tekin RPM 17.5, Savox 1258tg
cbaranski is offline   Reply With Quote
Old 12-25-2008, 10:16 AM   #12
8&stuff's Avatar
+1...on nova&rbs jp1 and jp2 work but usually run o touch hot..might be the way they were broke in? i just know my 1st nova 21 w/same tune within minutes i switched from jp1 running 240 to jp3 and jumped to 260+ and i lost a minute runtime.
Mark Buecker
Old 12-25-2008, 10:58 AM   #13
Mercury9's Avatar
Well thx for all that info, the only pipes i have at this this time is a JP1 and Ofna 086 pipe, im straped for cash at the moment but next time i well invest in the RB 2045/192 header (is that the right combo)..if i start my tunning at 4 turns out on the HSN my temps are like 200 and sluggish, ill need to most likly have to attempt a new tune at 4 turns out and 1hr increments...Is it normal to have to Rich-in it up from factory settings? Oh and one more thing could i change around the headers the ofna header is more staight and the JP1 is more of a ROUND header, not sure if it would make any difference..
Team Xray 808
Old 12-25-2008, 01:41 PM   #14
Originally Posted by Joey Platinum View Post
+1 .... very fast
thanks joey, you should see how fast it is in my MBX6, oh you will on the 3rd see you there!!
as for the your car and the temps just tune it for power and smoke the temp should fall in a good range also check this out man it may help a little bit
http://www.rchobbies.org/cars_eng-tuning.htm
